I was going to get Thermalright Ultra-120 Extreme, but when I saw this http://www.newegg.com/Product/Produc...82E16835154001 I got it instead. Pretty good deal considering Ultra-120 Extreme costs about $80 shipped with a fan.
Q6600 3.6Ghz @ 1.276v | DFI LP LT P35 | Ballistix Tracer PC2-8500 600Mhz @ 2.074v | GeForce 260 GTX | Auzen X-Fi Prelude | PCP&C 750 | Arch Linux ~ WinXP
AMD Athlon 64 X2 3800 | DFI LANParty NF4 SLI-DR | 2x512MB G.SKILL PC3200 BH-5 | OCZ PowerStream 520W | Palit GeForce 9600 GT | Gentoo
Long Live DFI.
comes up $64.99 for me :/
it's never fast enough!
yikes that ended fast...I saw the $45 free shipping
Intel Core i7 920 #3841A437 @ 3.8ghz 1.26v HT off
Thermalright True-120 Extreme
Gigabyte ex58-UD3R @ 190x20
6gb (3x2gb) G.Skill Pi @ 1520mhz 7-7-7-21-1T
PNY 8800gtx @ 640/1000
abs (tagan) 700w
Antec Nine Hundred
Seagate 320gb
LG 25.5" LCD
Logitech G11 + mx518, Logitech x530 5.1 + plantronics DSP500
Soon to be :
ASUS P8P67 Deluxe, Intel SB i7-2600k, G.Skill Rj-X F3-12800CL6D-4GBXH, MSI HD6950 2GB, Corsair 750AX, Intel 80GB G2 SSD, DELL U2410
Used to be: SaFrOuT
It's back, $44.99 shipped, hurry up if you want one
Long Live DFI.
got one, thanks
how good are the compared to the thermalright si128. should i even consider this. the only main reason i can see is you can set the fan up to point at the exhaust fan in the back of the case.
GIGABYTE G1.Sniper
I7 950---12GB F3-12800CL9T-12GBSR--GTX 460 hawk talon attack--300gb velociraptor
PC Power & Cooling Silencer 750 Quad
ASUS P8Z68-V PRO/GEN3
i7 2600k---GTX560 ti 2gb----16gb mushkin 997005---120gb mushkin chronos deluxe
PC power & cooling 750 quad
CPU - Lapped Xeon Quad X3210 @ 3.0ghz w/ Lapped Tuniq Tower @ 1.3750
Motherboard - Gigabyte DS3 Rev 3.3 F12
Memory - 2x1gb G.Skill DDR2-800 4-4-4-12 @ 2.1
Video - Sapphire X1950GT @ 600/1400 w/ Zalman VF900
Sound - AuzenTech xPlosion Sound Card, Logitech Z-5500
Hard Drive - WD Raptor 74gb-WD, 250gb-Segate 7200.10
Optical - Samsung 18X DVD-RW Sata, Asus DVD-E616A3T Sata, NEC Floppy Drive
Power Supply - Enhance ENP-5150GH 500W
Monitor - Acer 22" AL2216W
Case - P182B
Mouse & Keyboard - S510 Keyboard, MX518 Mouse
GIGABYTE G1.Sniper
Most likly you will have to lap it or it will perform on par with the tuniq. Plus another $10 you get $80 or $90 with a nicer fan.
for $45 the tuniq is a better deal performance/price
Case - P182B
TR 120 X tested several degrees better than Tuniq on majority of tests. It's regarded as the best air-cooler out there.
again, TR 120 X is not "80 to 90" dollars. It's much much cheaper than that, especially when you look around (shoppts.com for example)
