Originally Posted by
Stigma
it IS possible to stack peltiers, but in order to get a useful positive result you have to stack them in a "pyramid" comfiguration. For example have 1 pelt right over the coldplate, then a larger coldplate over that that is again cooled by 2 peltiers of the same strength.
Stacking peltiers scales up very badly however, and in general you are better off just getting the single strongest peltier you can find. If you "need" to get even lower temps, you need to be looking at some phasecooling instead, because when you start to use 3+ strong peltiers in a cascade you are allready using more electricity to run it than a strong custombuilt singlestage phasecooler.
-Stigma
