+ Reply to Thread
Results 1 to 9 of 9
Thread: Corsair CM2x512-8500 @ DDR 972 MHz | 4-4-4-8 | 2.24v
    Xtreme Enthusiast Timbosan's Avatar
    Feb 2006
    Australia
    0
    Yesterday i purchased a 1GB kit of Corsair CM2x512-8500 v1.4. At its rated voltage (2.2v) it is running 100% stable at 972 MHz | 4-4-4-8. Here's some initial tests:
    EDIT: i tried same timings and speed at 2.16v and stability is the same as with 2.24v
    Aug 2006
    0
    Nice.
    Feb 2006
    Australia
    0
    Ive done some more testing. I have to say i am quite impressed with this ram At 972 MHz it is at 4-4-4-4 with only 2.16v. I read that some people had experienced 8500 rated modules (various brands) not being able to run at their rated speed (1066 MHz) so i used the 1:2 divider and ran system at stock with ram at 1066. I tried it at 5-5-5-12 with only 2.16v and it passed 2 hours of orthos. They can do rated speed at tighter timings with less than rated voltage, so all good there.
    I will be pushing it in the next couple of days to see what they can do I will post some more benchmarks tomorrow. Here's a 3+ hr orthos to show stability.
    *anyone care to speculate on what IC's these sticks have?
    3D Team Captain Don_Dan's Avatar
    May 2007
    Munich, Germany
    61
    These result are very nice. Especially the bandwidth you achieved is very impressive I think!
    I speculate that these sticks use D9GMH chips...
    Quote Originally Posted by chew* View Post
    You can never have enough D9's.
    Feb 2006
    Australia
    0
    The read bandwidth in the first post is bugged i didnt realise i have re-done the everest benches with a new version. The read bandwidth is much more realistic than 14.4k lol.
    I did some hardcore gaming at DDR 972 4-4-4-4 @ 2.16v and it wasnt totally stable. Increasing it to 4-4-4-8 and pulling in the subtimings made it 100% game, orthos and memtest stable.
    The full timings are 4-4-4-8-5-30-5-12-6-12 @ 972 MHz @ 2.16v. It may handle a tRAS of 5 - 7 and slightly tighter subtimings but i havent finished testing. Anyway these are great modules
    May 2007
    Munich, Germany
    61
    Yes, now the bandwidth is a bit more realistic...
    When I saw it I just thought, damn, how can he get 80% more than I get at 800 4-4-4-11 1T... but anyway, it's still very good RAM!
    ICs?
    Feb 2006
    Australia
    0
    Quote Originally Posted by Don_Dan View Post
    ICs?
    I found that allendale cores cause incorrectly high read scores with everest versions <3.5. Now using v4.01.xxx its correct.
    I'd love to know what IC's these use too, i cant remove the spreader as its epoxied on afaik.
    May 2007
    Munich, Germany
    61
    According to the RAM List and the version you posted above, they should use Micron D9GMH (B6-3).
    http://ramlist.ath.cx/ddr2/
    Feb 2006
    Australia
    0
    Yeah thanks i saw that, but i have checked corsair's ram list and my modules havent been added yet, they are 2007 modules. All previous versions of this ram has used D9XXX, so i assume thats why the DDR2 ram list says micron.
+ Reply to Thread
