just was wondering if anyone had some tips or advice in order to experience the longest chip life. i have currently cool & quiet enabled which is helping a bit for temp. when idle.
thanks.
thanks.
AMD Opteron 165 @ 2.50GHz 1.40v
ASUS A8N-SLI Deluxe Bios: 1805
PNY 2x512 DDR500 / Kingston 2x512 DDR500 3-5-5-10 2T
eVGA 7800GT 256GDDR3 @ 445/1070
WD 640GB 32MB
ASUS 16x DVD-ROM / SONY 22x DVD-RW
Ultra X-Finity 600
I would have to say heat is one of the most important aspects to keeping a cpu alive. just make sure you have good cooling and you should be fine.
Well, don't overclock for one.
Oh wait, forgot I'm on XS :P.
Originally Posted by amscott
Heat and voltage.
Voltage causes electromigration, where the silicon semi-conductors inside your CPU actually cease to function. Heat just causes general degradation. Out of these two, though, heat is by far the more dangerous, as at anything less than extreme voltages (1.6V+), it will take years of 24/7 use for electromigration to render your chip useless. Basically, use the volts you need to to get the OC you want, but watch your heat outputs - for long-term use, try and keep your load temps under 50 deg C.
Rig specs
CPU: i7 5960X Mobo: Asus X99 Deluxe RAM: 4x4GB G.Skill DDR4-2400 CAS-15 VGA: 2x eVGA GTX680 Superclock PSU: Corsair AX1200
Foundational Falsehoods of Creationism
my AMD Opteron 165 is what im regarding to about this thread. for heat, what would be an good temp range to stay in to have optimal cpu life? under 50-55? and as for voltage, what would be 'ok' 'safe' to reach? im thinking of clocking a bit more but its going to need a bit more voltage. is 1.45 a good limit? just looking for rough ranges. thanks for the input too.
WD 640GB 32MB
Ultra X-Finity 600
yeah i know. it only gets to 50-55 when 100% both cores. i was thinking of getting another cooler. i dont want to exceed 1.45v hoping that its a 'safe' voltage to keep the chip going for atleast a good while. i was looking at the Zalman CNPS9500. is this one ok or is another one recommended? thanks.
WD 640GB 32MB
Ultra X-Finity 600
My 4800+ runs very hot naturally. It is running at 2.84ghz with only 1.38v yet I still get 50-55 myself without much effort. This is with many remounts and no change. My cpu is still running great since I first dropped it in last October. With such low volts I should be getting lower attemps but unfortunately I'm not.
Silverstone Temjin TJ-09BW w/ Silverstone DA750
Asus P8P67
2600K w/ Thermalright Venomous X Black w/ Sanyo Denki San Ace 109R1212H1011
8GB G.Skill DDR-1600 7-8-7-24
Gigabyte GTX 460 1G
Modded Creative X-Fi Fatal1ty w/ Klipsch Promedia 2.1
1 X 120GB OCZ Vertex
1 X 300GB WD Velociraptor HLFS
1 X Hitachi 7K1000 1TB
Pioneer DVR-216L DVD-RW
Windows 7 Ultimate 64
