keep us in the loop, looks like it'll be an interesting build
Damn looks nice, great looking condensers too. Should perform wickedly.
where did you get it from?
Bring back natural selection! No more warning lables!
The one and Only MG Pony
Looks very awesome. What are the dimensions of this thing?
Question tho, whats that port on the bottom with a cap-tube and filter/dryer. Does that compressor use refrigerant-cooling for the windings or something?
Fold for XS!
You know you want to
Oooohhhh... information? 4 ports? Err?
whoa... that is unsual kayl... I don't understand how that would be very effiecient, I always thought rotaries performed best vertical... but that would make space managment interesting.
Looking forward to a unit with that in it!
Also, what is that at the base? the black box? and the what is that small filter and captube like setup in the pick.. .that looks really odd.. gll mate!
Heatware | Ebay:Crazymullen | If you are unsure what Fhqwhgads means You are REQUIRED to go HERE| Powered by Centon Ram
IMHO Waste is a computer going to a landfill having done actual computations less than 90% of it's life. 90% of the computers powered on right now are idle or powered off; what a waste! [/B]
Is it a coincidence that your wifes pc is called Uranus?
Thats called liquid injection, used to keep discharge temps down and cool the compressor, it will be designed to be 1/10 of the total system capacity and would use a timed valve to allow squirts in as needed.
or maybe oil return, with a oil filter, i havent ever seen liquid injection on anything that small, unless it's a low temp thing
Awesome compressor kayl - do some majic with it.
I was running your kayl evap at 250w today along with a nf11fx. The evap did great. I think the condenser wasn't keeping up though. It would hold the load at 38c for a about 45min then it would overheat the compressor and the bottom fell out. I think with a better condenser I would have been fine.
looks pretty nice
IIRC chilly and his partner ( D blasco) had FS some horizontal rotaries
"Study hard my young friend"[/B].
Woody: It's not a laser! It's a... [sighs in frustration]
The capillary tube and filter on the bottom of the compressor is indeed for liquid injection to cool the compressor, It simply requires a 1/4" feed from the condenser discharge. Currently Kayl and I import these compressors into Australia, we only got a few to start off with so we can test their durability, performance and noise before importing larger quantities for use in SS and cascade systems as well as individual sale. But the horizontal configuration opens up a whole new world of possibilities, as the dimensions of the case can be kept similar to normal SS systems, but these compressors come in capacities from 0.75hp up to about 2hp, so multiple head units with high capacity are achievable. Now we only have to figure out how to fit big condensers in there too......
Yes but from where! I'd be interested in them as a fridge compressors as for a comercial install it would be ideal.
no i meant if small low temp compressors have liquid injection, and i had it in ? form in my head, but couldnt you have like a small [2"widex4"tall] phase sep thingie that a 1/8" line would come from the oilsep, a 1/4 from the liquid line, have those two at the top, and the outlet to the bottom, and then shorten the cap tube in the compressor by an inch so you still get the same amount of refrigerant in the compressor, and simple oil return!! yay!
Something like that could be possible, as if you run a cascade how would you work the liquid injection?
If you have a cooling question or concern feel free to contact me.
Can you do them in 240v at all?
Humm uber small cascade with 2 2HP's units!!! Plate HX, Ssliencer mount, Run MC evap, that be mental and what i want
but you wont be able to have it as you are getting moved :P
where are you moving to pete?
Asus COMMANDO -Intel Q6600 @ 3.6Ghz 401x9 have sum test @ 445x9 4GHZ :-)
2x74 Gig Raptors Raid 0..GSKILL 6400 2x1Mb matchd Pair.-OCZ 550w Powerstream adjustable rails- XE2 Vapochill -pioneer Dvd.-2x160 Gig Hitachi ide drives..-Asus 7600 gs video card
http://www.hwbot.org/user.do;jsessio...C3?userId=8636
[QUOTE='[XC] Lead Head;2306393']Looks very awesome. What are the dimensions of this thing?
QUOTE]
The total unit length is around 590mm, not sure on compressor length.
Im measure the compressor later and update this post k.
i bough these off Aussieguy, but if they go well might import a few myself from china. I want to see how well they go first though and if like to run for several hours etc without overheating.
Thanxs runmc, im glad ya like my evap, was that the latest one, or the earlier model cant remember now, was that one of the evaps i sent in the past?
It seems condenser temps greatly effect load capabilities and temps. Keep that condenser cool and ya can hold a bigger load. Thats one of the things i have about Aussie summer weather and cased units. Once ya have a hot room temps, systems loose a little performance, get better results in winter.
I havnt been having much luck with these compressors.
First unit finished was this one, It ran and I applied 300w load and in about 20mins the compressor overheated and shut down. I managed to get it to start again but quickly stopped. Seems its stuffed damit.
Speaking with the supplier (from china) so English barrier a little hard, but they are telling there isn’t enough refrigerant in the system and that’s why the compressor overheated. Heres a pic of what these compressors are normally used in, cool room freezer.
Now im just testing a suction line on this smaller compressor seen here. Cpu is working fine, so ill install it on this compressor and see how I go.
heres the unit so far though
Off course they won't run using them like that. You're lucky guys that rotaries do run in our working conditions without overheating... The air flow through the compressor must be even higher than what it used to run with.
