+ Reply to Thread
Results 1 to 9 of 9
Thread: Will a quad core work like this...
    Apr 2007
    0
    Let's say I'm surfing, listening to music, doing a virus scan, and doing a spyware scan. Would the virus scan be on one core, and then the spyware be on another, and then music on one, and the surfing on the last? Just curious.
    Xtreme Addict RAW-Raptor22's Avatar
    Jun 2007
    Northern California
    0
    Mmhhmm, yup.
    |-------Conner-------|
    RIP JimmyMoonDog
    2,130,223 F@H Points - My F@H Statistics:
    http://fah-web.stanford.edu/cgi-bin/...e=Conman%5F530
    Jan 2007
    0
    Probably yes , but its pointless if all this applications occupies the same hard drive.
    Xtreme Cruncher SoulsCollective's Avatar
    Jun 2007
    Perth, Western Australia
    0
    Sure, unless any of those applications were multi-threaded, which I'm pretty sure some AV programs are moving towards.
    Rig specs
    CPU:
    i7 950 @ 4.2GHz Mobo: eVGA Classified 760 RAM: 3x2GB Corsair DDR3-2,000 Dominator GTs @ 2,000, 8-9-7-24
    VGA: Crossfire Sapphire HD6970s SSD: OCZ Vertex 2 60GB HDD: 6x WD6400AAKS in RAID-6 powered by Highpoint RocketRaid 3520
    SFX: Auzentech X-Fi Forte w. OP637AU PSU: Corsair HX-1000 Case: Silverstone TJ-09 modded for WC OS: Win7 Pro x64
    Liquid-cooled
    -=- EK-Supreme HF -=- EK Classified FC -=- 2x MCR120 + MCR320, Scythe Gentle Typhoon 1850s -=-
    2x MCP355 w. XSPC Dual-DDC Top -=- EK-Spin bay res -=- 7/16" black Pro-LRT w BP compressions -=- Aquaero w. Powerbooster
    Peripherals
    3x Dell U2311H (Eyefinity) -=- Audio Technica ATH-AD1000 -=- Razer Mamba -=- Microsoft "Natural Ergonomic 7000" keyboard -=-
    Foundational Falsehoods of Creationism
    I am Xtreme NickS's Avatar
    Apr 2005
    Upstate, NY
    0
    Yup The pro about Vista is it's natively multithreaded, so it divvy's up everything equally between all 4 (or two) cores.
    Core i3-550 Clarkdale @ 4.2GHz, 1.36v (Corsair A50 HS/F) LinX Stable
    MSI H55-GD65 Motherboard
    G.Skill 4GBRL DDR3-1600 @ 1755, CL9, 1.55v
    Sapphire Radeon 5750 1GB
    Samsung F4 320GB - WD Green 1TB
    Xigmatek Utgard Case - Corsair VX550
    Hiding from the cops and people I ripped off
    Jun 2005
    In Bed
    0
    You'll find that windows uses core 0 more than any other cores. Depending on the program and if its not multithreaded the affinity wont automatically set itself to work over all 4 cores. So, if your running all those programs it wont spread evenly over all cores it'll lean more towards core 0 and 1. I've done this several times just to see how it works.
    Edit: This is assuming that your using XP Thanks Nick I forgot about Vistacrap
    YouTube Addict nn_step's Avatar
    Aug 2005
    Klaatu barada nikto
    2
    yep and if you want to manually set it
    nnstep.com/taskassign.zip
    Fast computers breed slow, lazy programmers
    The price of reliability is the pursuit of the utmost simplicity. It is a price which the very rich find most hard to pay.
    http://www.lighterra.com/papers/modernmicroprocessors/
    Modern Ram, makes an old overclocker miss BH-5 and the fun it was
    Apr 2007
    0
    There'd be 4 hard drives in RAID 0, which I guess I could have just said yea, one hard drive.
    So, XP won't do that?
    Jun 2007
    Northern California
    0
    Not automatically, but thru task manager it does.
    RIP JimmyMoonDog
+ Reply to Thread
