+ Reply to Thread
Results 1 to 6 of 6
Thread: Air Cooling a Quad Core
    Registered User AcuraDC5's Avatar
    Jun 2007
    0
    Is it feasible to overclock a quad core (Q6600) with air cooling? Which would be the best heatsink and how far would I be able to OC.
    Or would I HAVE to watercool?
    Please point me in the right direction.
    Xtreme Member xenoasd's Avatar
    May 2007
    Canada
    0
    i know some people here in xs and other forums have their quad core air cooled. some of the best heatsinks around are tuniq tower, thermalright ultra-120 extreme. you dont have to go to water unless ur going for like 4ghz.
    E6600 - 3.6Ghz @ 1.4V
    Thermalright Ultra-120 Extreme + S-FLEX SFF21F 120mm Fan
    Asus P5B-Deluxe WiFi-AP
    Crucial Ballistix DDR2-1000 2GB
    eVGA 8800GTS SuperClocked 320MB 650/1900
    Creative X-Fi XtremeMusic
    Corsair HX520W
    Antec 900 Case
    3DMark06 - 13,078
    Xtreme Member Riddlinkidstone's Avatar
    Jun 2007
    0
    You don't "need" watercooling. You can do it on air just fine.
    E6300 @ 3.6 1.5v
    Asus P5B-Deluxe
    2GB (1GBX2) Crucial Ballistix PC2-8000 4-4-4-15 2.4v
    Evga 8800GTS 320MB Superclocked
    320GB Maxtor 7200.10 SATA
    250MB Western Digital Caviar SATA
    80GB Seagate 7200.7 SATA
    Thermaltake Armor
    Swiftech MCR220-QP
    Swiftech Micro-Res
    Swiftech MCP665
    D-Tek FuZion
    Masterkleer 7/16" Tubing
    Dec 2006
    Alberta, Canada
    0
    With either type of cooling, worry about what your ambient temperature will be. On air or water this is going to have a large effect on your temps and thus overclocks, e.g. if your ambient is 18C you will be fine for either, OC or not. If its 28C you will be hard pressed with air or water to OC well.
    Xeon 3060 @ 3,600 MHz [400 x 9, 1.36v] - Ultra 120 Extreme w/ FN121s Push/Pull - P5B Deluxe [1236] - 2 x 1GB G.Skill "HZ" @ 800 MHz [4-4-3-9/2.1v] - EVGA GTX 260 650/1400/1150 - PCP&C Silencer 750 Quad - TJ-09
    Xtreme Legend DDTUNG's Avatar
    Jun 2002
    Hong Kong
    0
    The new G0 stepping chips can be OCed reasonably well with air coolers such as the TT120 or Ultra-120 X.
    DDTUNG
    XtremeSystems - we overclock and crunch you to the ground
    I left the optimized files on three 3GHz P4 HTs. Ban me.
    Xtreme Member davexl's Avatar
    Nov 2005
    Melbourne
    0
    My 3 Q6600 systems top out at 3.5 to 3.55 GHz on air cooling with the Ultra-120 Extreme.
    (P5B and P5K deluxe)
    Intel Core 2 Duo 6400 & 6600's
    6400: 2.1GHz overclocked to 3.360 Ghz, 1.450V Vcore, Asus P5W-DH Deluxe, Rev 67MOAG BIOS 1305 -TTBT
    6600: 2.4GHz overclocked to 3.600 Ghz, 1.5375V Vcore, 3.708 Ghz, 1.5750V Vcore, Asus P5W-DH Deluxe, Rev 68MOAG BIOS 1602 - Ultra-120
    QuadCore Q6600: 2.4GHz oc to 3.456 Ghz, 1.5625V Vcore, Asus P5B-Deluxe Wifi, Rev 1.03G BIOS 804 - Ultra-120 Extreme New Build, still testing.
    Gskill F2-6400PHU2-2GBHZ (4 x 1GB)
    Antec Truepower2 550w EPS
+ Reply to Thread
