I'm toying with an idea of modding the 320bit bus on the 8800GTS into 384bits...
You know, the 8800
GTS has 12 GDDR chip solder pads like 8800
GTX but only 10 are populated and the GPU (mem ctrl) is the same. So, I'm thinking why not? I got the needed chips, two (eight actually)
Samsung K4J52324QE-BC12s, the SMD caps, resistors and what-not needed for the pads on the backside. But most importantly soon also a
hot air soldering iron for soldering the BGA balls...
Sounds reasonably safe, doesn't it? No?
Anyways, the "only unsolved problem" (yeah right) is to mod the BIOS from 320bits to 384bits.
Some thoughts about the bus width problem:
- NiBiTor 3.4a doesn't allow bus width manipulation
- reverse engineer the bus width bits from a BIOS of a GTX (mission impossible?)
- flashing a GTX BIOS into the GTS (atleast it "should" be reflashable back to GTS given the card were not to fry instantly)
Input would be appreciated regarding how to enable the extra bus width once the hackjob is done.
btw, the card is errr...
relatively disposeable so there's no need for anyone to run around screaming
"Don't do it man!!1!one1!".
