Results 1 to 2 of 2
Thread: Dehumidifier questions
    Jun 2002
    Columbia, SC
    Is there any problem with running -40C liquid through a regular Eheim 1250? Anything special that need to be done to it? Will it shorten the life-span?
    Also, is a 15-pint dehumidifier strong enough to run a chilled water system with?
    2xTualatin 1.26 (1.51)
    MS-9105
    256MB Corsair XMS2700
    http://www.whatisrazar.com/
    Jun 2002
    Vancouver, BC, Canada
    i would check the pumps specs
    they do list what temps the pumps do/can operate at....
    but i dont think your average pump will work at -40C
