+ Reply to Thread
Results 1 to 7 of 7
Thread: Computer is making a ringing noise...
    Registered User vicMasters's Avatar
    Aug 2006
    0
    About a week ago my PC started making this continuous ringing sound, and it's getting so freaking annoying, I can't take it anymore. I thought I'd come here to see if any of you guys had any idea what might be causing it? Which component might make a ringing sound if it's about to stop working, and needs to be replaced?
    c2d E6600|p5b|2GB.G.SkillHZ|TT Thermaltake|7600GTKO
    Registered User bizkit35461's Avatar
    Mar 2006
    0
    What kind of monitor do you have? I know that it's possible for CRT's to make a high pitched noise. Hope that helps some..... Good luck!
    Lian-Li V2000B | Intel Q6600 G0 @ 2.997Ghz (333 x 9) | DFI LP UT P35-T2R | Corsair 750TX PSU | Team Group Xtreem Dark DDR2-800 4GB | Seagate 500GB HD | EVGA 8800 GTS [G92] 512MB | Danger Den MC-TDX | Danger Den IONE GPU Block | ThermoChill 120.3 w/ 3 Yate Loons | Swiftech MCRES | D5-Var Pump | Tygon 3603 1/2" Tubing
    Aug 2006
    0
    Its a 19" acer lcd. Im 100% sure thats not what it is because I play my 360 on that monitor and I dont hear the ringing. Im thinking maybe its one of my fans. But id like to be certain before I replace any parts.. Any other suggestions?
    Xtreme Cruncher Emerica's Avatar
    Apr 2006
    Tampa
    0
    I think it's one of the fans too. Unplug them all one by one and see if the ringing noise goes away.
    Workstation :
    Q6600 @ 3.2ghz/Scythe Infinity (Screw mount mod)
    GA-P35-DS3L (F7)
    4GB G.Skill @ 400mhz 4-4-4-12
    BFG Nvidia 7600gt
    WD 250GB SATAII 16MB (OS/Programs)
    Seagate 250GB SATAII 16MB (Storage)
    NEC DVD+/-RW
    Antec NeoHE 550W
    X-Fi Xtreme Music
    Razer Copperhead
    MS Natural Ergonomic 4000 (Best KB ever!)
    Windows 2008 Enterprise Server x64
    Laptop:
    Dell Latitude D610 - Pentium M 750 1.86Ghz / 1GB RAM
    Xtreme Cruncher justin_c's Avatar
    Sep 2006
    Canada
    0
    ringing or whining/squealing. can be the power section of the mobo or gfx card.
    Xtreme Cruncher Polizei's Avatar
    Nov 2006
    'burb of Cleveland, Ohio
    1
    My power supply is making a ringing noise, good thing Im RMA'ing it. The only thing that stops it is flipping the switch on the back of the supply... noise is still there when the computer is off.
    Aug 2006
    0
    Yea, I just discovered it must be my power supply. All of my fans are fine. Wish I could RMA mine but I got it at compusa. Guess I'll just wait till I buy my 8800.
+ Reply to Thread
