I'm at a bit of a loss at this point and was hoping someone could point me in the right direction. I just finished my first real water cooling setup and my temps are no were near what I was hoping for. Searching through threads for similar specs there seems to be something wrong and my temps are too high
Specs:
1 Loop with CPU only
e6600 402x9, 1.525v 1.47v min w/ vdroop
DS3
4gb Patriot Extreme 2x2GB Only good to 405 do to a weak stick
Apogee GTX ( Bowed )
MCP655
2xMCR320-QP-K in series
Micro Res
6x120mm ( Evercool EC12025M12C )@12v
1/2"ID Tubing
P180
1/9 ( G11/water +2 drops of algae killer )
Difference between load and idle temps are between 15C-20C.
My goal was to hit 3.6 and drop my fans to 7v. I know the 2 rads are overkill but I figured I 'd be trying a quad core soon enough and wanted to be prepared.
Everything is top mounted. I have rechecked the rads at least 3 times and have rotated them in every direction in an attempt to find any trapped air. I have also tried both MX-1 as well as AC5, reseating twice with each compound. Neither have sat for more then a day so I know temps will drop a couple degrees over 3 days but not enough to get me were I want. I also rechecked how I seated the bowed block to be sure it was going across both cores.
What do you think I'm doing wrong?
