GL on 1800MHz and above!
My first XP last year was an AGOGA Y 1600+ and it did 1780MHz no problem on both my 8k7a and 8kha+. To bad I killed it.
Cursed be the ground for our sake. Both thorns and thistles it shall bring forth for us. For out of the ground we are taken for the dust we are and to the dust we shall return
Heat
I have this one at 1838mhz 1.92 volts. Still havent found out whats stable yet. The bios in this Abit KX7 333R is very confuseing to me.
What do you have your FSB/Multiplier set to?
I have mine at 10.5 X 173 1820 > 1.92vcore. I just volt modded my KX7, so I'm hoping to get more.
stock multiplier.......i dont dare try to unlock this processor. to afraid of ending up with nothing working again
front side bus is 175.........i had it into windows at 181 fsb. even made with stock voltage at 1806mhz
Jen
had an aroia 1600+ that would do 1850mhz at 1.75vcc but no more..... have an agoia 1600+ that does 1970mhz now at 2.0vcc but no matter how hard i try or what i shut off/tweak in bios on the 8k3a it just wont hit 1980mhz .... 10.5X 187 is it.
I just picked up a 1600+ and am in the middle of unlocking it... whoo! what a pain... anyway its a
AGIOA Y
AX1600DMT3C
If I don't screw it up unlocking it I'll be posting results tonight.
AMD & ATI Powered!
DFI Lanparty S939 NF3 Ultra-D | AMD X2 4200 @ 2.6GHz | 1gb OCZ pc3200 rev2 TCC5 | ATI X800XT Platinum Edition| 2x120G WD | Plextor 712a | Antec SLK3700AMB| 520w OCZ PowerStream | Zalman 7000Cu
My Heatware 100% Positive
Good luck with your new chip, LBJGH
E8600. EP45-UD3P. 500FSB 24/7. Still WinXP. Heatware
Well here is the finished product... I hope it works
AMD & ATI Powered!
LBJGH,dont install it yet.i saw that pic and had to register.the triangle and where it says L1 are grounds and it looks like you have them covered.so you might want to scrape it away from there.i think you will just be locked at 11 but why take the chance on frying it.
will the triangle ground the L1's?
AMD & ATI Powered!
the triangle and L1 are grounds,when you connect the dots dont let the conductive paint touch them
Mine :
AGOIA 0212 Y
1.95 Ghz for benching, 1.92 Ghz for 24/7 use
14162 pts AXP1600+/Ti4200
Figure I'd add mine to the thread also....AROIA 0213 Y
T-bred B 2100+ @ 200x12.5 Aircooled
Abit NF7-S 1.2 @ 1.85v/1.7vdd/2.9vdimm
2x256 Corsair PC3200 2/4/2/2
1 80gb WD HD (8mb)
2 120gb WD HD (Raid 0...thank you Abit!)
Leadtek Ti4400 @ 318/697
Pioneer 16x Dvd
Optorite DD0203
To be considered a country, you need to have a beer. Sure, it helps to have an airport, or nuclear weapons, but at the very least, you need a beer.
Cool, it looks like I may have found a 'good' CPU! I removed the conductive material from the triangle and the L1 so it should be good to go... the only problem is my epox mobo is giving me a C1 error and would not post. I didn't want to put the new cpu in until I sorted out the C1 error. I've just RMA'd the mobo and ram since I don't know which one died on me... looks like another couple of weeks before I can try the new CPU.
AMD & ATI Powered!
LBJGH lets hope you have as much success with your xp as you have with that TB.... Awesome overclock m8.I'm trying for a 50% o/c but need some better ram than my 256 hyundai 2100.
.... I'm assuming you started with a 1600+? Isn't that comparable to a 2400+ with those speeds?
AMD & ATI Powered!
Yer LBJGH forgot to say that it's a locked xp1600 AGOIA Y which cost me fifty pounds.I'm not too sure on the comparable clock speeds but it's a little unstable at this speed.Just under 2 gig seems fine though.But... if you were to kindly donate your stick of ram to me!! LOL
Sorry I just RMA'd my mobo and ram because of a C1 error code on my Epox mobo. I couldn't determine if was the ram or board... if the ram is toast, you're welcome to it (shipping not included.)
AMD & ATI Powered!
I was only kidding m8 ! but thanks anyway for your generous offer
me too...Originally posted by Bucket-head
AMD & ATI Powered!
Just got a AGOIA week 21 from newegg. This sucker is well into prime @ 160x10.5 ~ 1683mhz @ stock voltage (1.76v in bios) Still unlocked since it's actually for someone else. Since I'm not fsb limited I'll see what she tops out at soon. These things rock!.. My xp1800 won't even do 1600mhz without extra juice!
And I am on AIR at the moment also. Swifty 462 with an 80mm casefan..not the delta!
DFI NF4-SLI Expert
3700+ CABGE 0515SPMW @3.2ghz (291x11) 24/7
Prometeia Chilled!
7800GTX Watercooled
TwinX1024 XMS4400C25
WD 74gb Raptor
Dell 2405FPW
www.LATENIGHTBOYS.com
