+ Reply to Thread
Results 1 to 9 of 9
Thread: Anti-Vibration Fan Mounts for Open Corner fans
    Xtreme Mentor
    Mar 2007
    4
    Do these actually work and if so whats the best brand to get?
    Xtreme Recruit
    Jan 2007
    0
    I suppose it would work a little bit, but the main noise from the fan comes from the bearings inside the fan, and the fan spinning, pushing air.
    So all in all, its a bit pointless.
    Banned
    Jul 2004
    Scotland
    0
    A lot of the noise is indeed vibration through the chassis, you are right to want to isolate the fan body from case, here these will work woinders and are the thickest on the market but cost bit more.
    http://www.acoustiproducts.com/en/fan_gaskets.asp
    Avail in Black and Clear/white.
    Xtreme Addict ineedaname's Avatar
    May 2006
    Canada
    0
    In my case the most sound comes from the motor itself.
    But in my case i have very high powered fans.
    CPU: Q6600 @ 3.6ghz G0 Week 37B
    Mobo: Asus P5k Deluxe
    Cooler: TRUE 120 (150cfm Delta)
    2xHR-05
    2xHR-09
    Mem: G.Skill 4x1Gb 6400HZ
    Vid: HIS 4850
    HDD: 80Gb 16mb Cache Raptor
    500Gb 7200.11 Seagate
    PSU: Enermax Noisetaker 600w
    Case: Thermaltake Armor (4x120mm 104CFM Panaflo)
    3dmark06: 16k
    Banned
    Jul 2004
    Scotland
    0
    So do I but I use a controler, no need to be running PC overclocked 24/7 to surf WWW etc, your fast fans will also be generating a lot of harmonics, a Gasket would help somewhat.
    Xtreme Member Cybertronic's Avatar
    Oct 2005
    Newcastle, UK
    0
    Quote Originally Posted by humeyboy View Post
    You are better off with the Ultra-Soft Fan Mounts instead because according to silentpcreview.com's AcoustiProducts Vibration Dampers article , the fan mounts absorbs more noise than the fan gaskets
    Xtreme Mentor
    Mar 2007
    4
    Quote Originally Posted by Cybertronic View Post
    Yah but that review is very very old....
    Here is what I just bought:
    http://jab-tech.com/4-Pack-Delux-Ant...s-pr-3661.html
    Going to use them with these fans:
    http://www.sidewindercomputers.com/de12trblhisp.html
    What do you think?
    Banned
    Jul 2004
    Scotland
    0
    Not really as I do see where your coming from as the screw could still touch case metal going through the hole but not true that they will have 4 tiny surface areas where as gasket is 100% surface area, thats why I mounted mines with both the gasket and the rubber plugs, I have no screws or metal to metal near each other.
    Jun 2005
    0
    Jesus, or you guys could stop being do damn pedantic about noise.
    Do you, or will you ever hear the fan's slight vibration against a panel? Then it's not down tighly. Or does your whole case rattle? Stop buying $30 hunks of tin then fitting them with $35 fans.
    if you want silence, get quiet fans (yates?) undervolt them, and then throw the whole thing inside a thick wood cabinet (1" walls, anyone?) lined with whichever damping material you want, with small slats at the front and back for cables and air.
    But please, stop supporting the pointlessness of overpriced goodies like these.
+ Reply to Thread
