I'm just trying to figure out where and how to setup the fans in this case i'm gonna buy. I'd like to keep the bottom drive bay so i'm looking to mount the rad at the top. I have 2 options though, for one I can cut a 120mm blowhole in the top and mount it that way, and the other is with a custom back plate that uses a 120mm hole above the power supply mount. I'm looking to make this computer quiet and good for overclocking so where would you put fans, and how would you have them setup (intake/exhaust)? This is what I was thinking...
2 front 80mm intake
2 rear 80mm intake
2 120mm push/pull on rad, intaking from the top
Either 1 120mm or 2 80mm's exhausting above the psu
Do you think this will be quiet using fans that are no higher then 30dba? I plan on using a Dtek heatercore, hydor L30, good 1.2" tubing, bayres, and blocks for the cpu, vga, and possibly chipset. Any advice would be greatly appreciated.
