+ Reply to Thread
Results 1 to 6 of 6
Thread: Dual Loop In a Antec Super Lanboy
    Jun 2007
    0
    Question Dual Loop In a Antec Super Lanboy
    Has any one got any pictures of a Super LanBoy with 2 loops? Or any advice
    for this setup.
    I am working on installing 2 loops and need some advice.
    One loop for 7900GS 3/8 tube,120mm Swiftech 120mm Rad and Swiftech Block.Pump for this block will be a DangerDen CSp-Mag. Rear mounted rad.
    2nd loop with Hardware Labs 120mm Stealth X-flow Rad and 1/2 inch tube.
    Swiftech Cpu Block, Apogee GT and Petra's modded DDCT for MCP355 18w.
    Front Mounted Rad.
    I already Have all these parts from other older builds.
    I have Already modded the case for both rads.
    Xtreme Cruncher Grinch's Avatar
    Jun 2005
    Lakeland,FL
    0
    welcome to xtremesystems...and good luck...
    750W Thermaltake Modular PSU
    DFI UT X58-T3eH8
    Core i7 920 @ 20 X 200 1.325V
    CORSAIR XMS3 DHX 4GB (2 x 2GB) DDR3 1600
    768 MB EVGA 8800GTX
    1 X 36GB WD Raptor
    2 X 150GB WD RAPTORS
    1 X SpinPoint P Series SP2504C 250GB
    1 X Maxtor 6L300S0 300GB
    16 X NEC DVD Burner
    7 120mm Yate Loon LED Intake Fan
    4 120MM Yate Loon Exhaust Fan
    28" HANNSPREE Monitor
    Watercooling Loop:
    1 X PA120.3
    1 X PA120.2
    2 X Laing DDC's w/EK-DDC Dual Turbo Top
    7 X Yate Loon Blue LED Intake Fans
    4 X Yate Loon Blue LED Exhaust Fans
    1 X Swiftech GTZ
    1 X GPU EK Fullcover Waterblock
    1 X XSPC Dual Bay Reservoir 5.25" with Bubble Window
    Xtreme Enthusiast p8ntslinger676's Avatar
    Oct 2006
    Austin, Texas
    0
    i had a previous loop in a lanboy and it was very very cramped, i suggest getting a full atx tower otherwise you might now be able to fit everything.
    Media PC:[AMD x2 4800][MSI K9N-SLI][2x1gig Corsair DDR2 800][ATI 3650 AIW][Asus Xonar D2X][500gig Samsung SATA][Crap Antec Case and PSU]
    Jun 2007
    0
    Smile dual loop lanboy
    I already have most of the stuff fitted.
    It will be full that is for sure.
    Will post some pictures when i get it going.
    Xtreme Enthusiast Ad1tya's Avatar
    Oct 2005
    Mumbai, India
    0
    Aah.. Good luck with that.
    I had a hard time fitting a Single loop in there...
    CPU : E8400
    Motherboard : Abit IP-35 Pro
    Memory : GSkill DDR2-800 2GBHZ @ 1:1 445 4-4-4-12
    Graphics Card : Palit HD4870 Dual Sonic
    Display : Dell E228WFP
    Storage & OS : 1TB | Windows 7 64bit
    Sound Card & Speakers/Headphones : X-Fi Platinum (HotRod) > Zero DAC > BeyerDynamic DT990 Pro
    Peripherals : Razer ProType Keyboard | Steelseries Ikari Optical | Razer Goliathus Speed.
    Case : Coolermaster ATCS 840
    PSU : OCZ GamerXtreme 700W
    Xtreme Cruncher
    Jun 2006
    Iowa State
    0
    Yeah good luck, It's hard enough to fit ONE loop in a regular sized case, let alone two. It can be done, as you will find out, but it won't be easy! I would like to see how you do it though! Again, good luck!
+ Reply to Thread
