Results 1 to 2 of 2
Thread: Water cooling in a pc65
    Jun 2002
    I have a lian-li pc65 usb :http://www.lian-li.com/product.php?a...ewPD&prdid=369
    What I now need you help with is figuring out a solution in which I recieve comlete water cooling in this case. I was thinking:
    http://kylning.com/product_info.php?...products_id=96
    Good? Shouldn't have to be very efficient, but look good through the plexi of my case. Was also considering:
    http://www.overclockers.com/articles549/
    Anyhow, the fitting of it is the most important, no drilling shall be done. Thank you for taking you time to answer.
    Nov 2001
    Wichita, KS
    Im not sure I follow exactly what your curious about here. Are you looking for advice on what to get?
    If thats it, heh, Sorry, I dont know the kits all that well. I hand build and buy the parts seperately myself.
    Luck
    IFMU
