Ok, I just got my new mobo and finished getting everything hooked up and installed. The mach took a little longer to cool down then normal, but it had not been started in two weeks. After running for about five minutes there was a pop, not to loud and not the normal oil sound, followed by a hissing. The temps jumped quickly and I shut off the computer. I removed the head and restarted the mach, a little more hissing and the temps started to rise. I shut down the unit and the wounded mach is just sitting there.
So, what do I do from here? I compressor got really hot, do you think it is ok? I think the hole is in the line that goes to the head (heat exchanger line?). What gas should I use, as I'm sure that there is not more. I have lots of r502. Any others I might what to use? Thanks for the help.
