Its out ...
here
Yipee
Chris
Its out ...
here
Yipee
Chris
Normally resellers sell it a bit cheaper than Swiftech's online store price. I wonder how much it will go for street. Any resellers wanna chime in with their prices?
MM Extended U2-UFO CYO (Duality front, Standard back, Horizontal Mobo brace) Anodized Black || eVGA X58 || Intel i7 920 || 6 GB Corsair Dominator PC3-12800|| eVGA 295GTX || Asus Xonar Essence STX || VisionTek 650 TV Tuner || 1 300GB WD Velociraptor || 1TB WD's Black Ed. || LG 22X DVD-Writer || Lite-On 20x DVD-Writer || Corsair CMPSU-1000HX PSU
CPU Loop: DDC-2 w/ XSPC Reservoir Top -> Swiftech GTZ -> Thermochill PA120.3 (Push: 3 Scythe S-Flex G)
GPU Loop: DDC-2 w/ XSPC Reservoir Top -> (Koolance VID-NX295 FC block) ->Thermochill PA120.3 (Push: 3 Scythe S-Flex G)
Chipset Loop: DDC-2 w/ XSPC Reservoir Top -> Alphacool Silentstar Dual HD waterblock enclosure -> Bitspower Black Freezer eVGA x58 MOSFET-> Bitspower Black Freezer eVGA x58 NB -> Thermochill PA120.2 (Pull: 2 Scythe S-Flex G)
2 x Dell 2408FPW LCD || Logitech Z-5500 Digital 5.1 || Logitech G9 Mouse || Logitech G15 LCD Keyboard || Logitech Quickcam Ultravision || Sennheiser Headphones
Does the design principle sound like the Fuzion GFX + Unisink?
CPU: INTEL Q9550 E0 @ 3600 1.28V + CORSAIR H50
GPU: EVGA GTX 480 @ 725/1450/3800
PPU: EVGA 9800GTX @ 738/1836/2250
MB: ASUS P5E X38
RAM: MUSHKIN 2X2GB
SOUND: X-FI TITANIUM FATAL1TY | LOGITECH Z-5500 | LOGITECH G35
HDD: WD 76GB X 2 RAPTORS RAID 0 10KRPM | WD 1TB CAVIAR BLACK 32MB STORAGE
PSU: CORSAIR HX1000W PSU
OS: WINDOWS 7 PRO X64 OS
MON: HANNSPREE 28" 1920X1200 RESOLUTION
Roughly, yes. But I'm hoping it will be less restrictive than the Fuzion GFX. More in the lines of the MCW60.
In fact I'm hoping for a MCW60 without the fiddling with a dozen of small HSs for the rest of the chips.
We'll see...
Edit: Slap me in the face, please. I've forgotten half of my physics already. What was the relation betwen psi and mmH2O? Reason being the pressure drop graph in the MCW60 is in psi and the Stealth one in mmH2O.
phcjpp... someone beat you by 8 minutes... didn't you see a thread already on the forums? Perhaps the mods can merge these threads?
Ah ... I was too busy emailing Petra and ordering 2 to notice !
Chris
The idea behind the stealth may be good, but the block is horribly restrictive. Many people stopped considering the Fuzion GFX when they learned of its large pressure drop. The stealth's pressure drop is nearly twice as much. I compiled this table from the Fuzion GFX, MCW60, and Stealth's pressure drops.
Flow [.5,1,1.5] GPM
Fuzion GFX [.5,1.8,3.9] PSI
Stealth [.9,3.6,7.8] PSI
MCW60 [.1,.3,.8] PSI
I wouldn't put the stealth in the same loop as a cpu as it will absolutely kill flow. It makes me wonder if the pressure drop on the swiftech site is accurate...
My 2 are in their own loop powered by an Iwaki RD30
Chris
Where did you find the figures for the Stealth?
A wolf in wolves clothing.
IMO $109.00 USD is too much money to spend for VC WB. MCW60 & MC14 heatsink pkg... FTW
Lian-Li PC-75B, Asus P5WGD2 WS Pro (BIOS 502), Intel Q6600 G0@ 3.5GHz 1.50V, G.SKILL BHZ, 2048-6400C4,4:3@5-5-5-15-5,EVGA GeForce 8800GTX 768MB, CC-644MHz / MC-1100MHz, HT OMEGA CLARO 7.1, Logitech z-5500 5.1, Enermax 660W SLI, Boot Drive - Raptor X WD1500AHFD 150GB, Two Storage & Backup HD's-WD 320GB SATAII inclosed in ICY Dock Hot swapable HD racks, NEC DVD +/-RW ND-3550A, Lite-on DVD ROM SHOD-16P, 52-in-1 cardreader, Deck Legend-Ice Keyboard, Back to my Logi MX500 @1000Hz
-monitor#1 Dell 2407WFP rev. A04, res. 1920x1200
-monitor#2 TV Vizio GV42L, connected with 30' RapidRun cable, Audio - 30' S/PDIF, Belden/Canare cable-> Marantz AV9000 5.1-> 5X 600w ADCOM monoblocks, Veledyne SPL-1200 Sub, SpecResearch keyboard.
Custom Watercooled->CritiCool PowerPlant PCI Relay Card(modded)->Meanwell S150->Iwaki RD-30-> PA120.3 w/ shroud & Yate Loon D12SL-12 Fans, Nexus fan controller->Storm G5->MCW60
Hmmm... 2.5 mH2O = 3.6 psi? Is not a tricky question, is just that I'm not used to mH2O as unit of measure...
Edit: Ok, I took my conversion tables out and... yup... is 3.556 psi. Well, if the figures are correct, this block is a no-no. Is even worse than the one I'm going to ditch. . I let the opportunity of buying MCW60 for 10 quid go waiting for the Stealth.
It's freaking priced right as well.
Pressure drop? Mine will be run independently, and I don't even mean SLI in one loop. I mean each video card in its separate loop, with more head pressure than a RD30.
They had to release it on a weekend! Meaning that I can't install it until next weekend! What a drag
No ing way! I WANT info on how this block performs in real life by the end of today.
You have four hours to get hold of one, rig it, test it and post your results.
Oh, and milk, no sugar, thanks.
By the way, I've seen no insults directed to you in the past few days... are you getting senile or something?
holy smokes that's crazy restrictive.
Lenovo Thinkpad X220 - Core i5 2410m, 4gb
waiting on 28nm video cards...
Unless you are volt modding your GPU, the added performance of something like the Stealth vs. an EK FCB is totally unutilized. And if you are volt modding, then you probably want a block that cools the vregs as well since you will be driving a lot more current through them.
I'll be purchasing one to test it out. I'll reserve judgment until I see it in action. However, I really hope Swiftech reconsiders the use of Alu. I know they plate it according to mil-spec (which is far and away better than any other manufacturer), but the reason for doing so is just for looks. It seems to serve no purpose other than for looks.
Gabe, I love your waterblocks. But seriously, most of us don't care what a Swiftech product looks like as long as it owns the performance crown. Ditch the alu "sporty" covers already.
