+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 25 of 31
Thread: New OCLabs TOP UV for DDC 1T/1TPLUS
    Registered User Gioz's Avatar
    May 2005
    Italy(Mantova)
    0
    These are new OCLabs prototypes of alternative top for DDC pumps.
    -Uv reactive
    -New design
    -and something else
    Official preview and test result coming soon
    Feb 2007
    0
    i like the left one
    Banned Pete's Avatar
    Apr 2006
    Portishead, Bristol, England
    0
    Please for the love of god let it have some tweak to give it some proper head presure
    Xtreme Member migueld's Avatar
    Dec 2006
    0
    I've been meaning to try the OClabs top, the left one. It's the cheapest decent DDC top. I don't know if I like the new design, the barb area seems fragile. That's the main thing that bothers me. The channel is bigger, so that'd be an interesting thing to test...
    Apr 2006
    0
    Rain water will move faster around the globe than out that new top! I agree the barb fitting looks too risky.
    Yes there current top is by far the cheapest going on the merket you can get but it's not as good as the Petra 01s which really gets the pump working to make power
    May 2005
    Italy(Mantova)
    0
    pump + top
    P.S.
    i'm going to suggest a crash test!
    Dec 2006
    0
    Quote Originally Posted by Gioz View Post
    pump + top
    P.S.
    Sexy, hmm, that looks like it's a stronger plastic than acrylic? It seems it's been molded rather than machined.
    Jul 2006
    0
    looks like a molded top(like stock but with proper barb placement) also looks like the pump housing to impeller clearance is allot tighter(head should be real good as long as the inlet/outlet isn't too big) cant wait to see test results
    “You Americans are so gullible. No, you won’t accept communism outright, but we’ll keep feeding you small doses of socialism until you’ll finally wake up and find you already have communism. We won’t have to fight you. We’ll so weaken your economy until you’ll fall like overripe fruit into our hands." Nikita Khrushchev
    Xtreme Member Senater_Cache's Avatar
    Sep 2006
    Miami Beach
    0
    so the outlets are 1/2" ID?
    Mar 2007
    Italy, L'Aquila
    0
    Hello to everyone
    Here is the first "quick" test results:
    PlexyTop (~0.43bar): http://www.oclabs.com/res/articles/1...ddedclosed.jpg
    XPTop (~0.46bar): http://www.oclabs.com/res/articles/1...ttaclosed1.jpg
    That's only a little preview, we didn't make any test with DDC350 yet and this is just Prototypes Tops. Probably at the end of next week, we will have here the pre-production samples and after the new test (mechanical resistance, flow rate, pressure, etc...) we will pass to the production XPTops.
    The barbs hose are 1/4Gas BSP and the tops is a Mix of alternative and CNC production to pass over the mechanical CNC design limits.
    Here is also the Preview link: http://www.oclabs.com/particles.php?docid=1323
    Kind regards, Nikos
    Nikolaos "Nikos" Kavvadias - OCLabs products designer.
    Apr 2006
    0
    It all most looks like glass!!!
    I still say the outlet is way too big Nikos.
    Banned
    Jun 2006
    in a Red Rage D....
    0
    they look pretty. prettier with some metal high flow barbs...
    Mar 2007
    Italy, L'Aquila
    0
    Quote Originally Posted by Defiant View Post
    i like the left one
    The left one was a nice project but now it's out of production since April and will be also definitely going out of stock this week
    Quote Originally Posted by Pete View Post
    +0.03bar ~ +30cm
    Quote Originally Posted by migueld View Post
    Yes, it's true, it's the cheapest Top because I have decided to make it the cheapest one and this new Top probably will have the same price for the base version and something more for the UV reactive version.
    About the fragility of the lower barb, be sure that this new design will be more resistance than the actual CNC top (left one on the pics). The PlexyTop material is a high quality "metacrilato", but I ensure you that will never be a better quality material on absolute mechanical resistance as the new acrylic materials that we have already test on this prototypes. The next pre-production samples will be at least more resistance over 50% than the actual prototypes and they will be about 200% more resistance than the CNC PlexyTops...
    http://www.xtremesystems.org/forums/...=145173&page=2
    http://www.xtremesystems.org/forums/...9&postcount=33
    Quote Originally Posted by _G_ View Post
    Stock Top is made with PPS (Polifenilensolfuro) plastic, that's a special plastic material that injected in the machine over 380°C degrees and costs 3 times more than other normal plastics because when it becomes cold assumes some metal properties for industrial use. The material we have used for the prototype was only a quick test to see how was the trasparency effect, the new performances and of course the new UV reactive effect that seems perfect...
    Perhaps of the trasparency effect ?
    I can change the outlet way in 2 hours of work in the factory if I'll decided, but honestly I don't think that I've to change something as I was working on this project over three months to reduce vibrations and noises. I don't want to make the XPTop have 1% more head pressure than now (+0.03bar Vs PlexyTop) and breaks the DDC motors every week. My point of view, it's to design always a trusted product that will give 100% warranties to the customers, not a Dragster that brokes the engines on every pass.
    Kind regards, Nikos
    Apr 2006
    0
    Nikos this guy thats tested all the tops said that Alphacool was best which is a load of crap.
    I have a Petra 01s here, i've one of yours coming and a Alphacool.
    I'll clean them all up then i will do a test with them.
    I can test it on 3 differnt pumps
    The newest DDC that us in the EU have, the one that can be modded to 18w.
    I also will have the most comen version in the USA which is the orange 18w one.
    I'll put my hand down that Petra will win, followed by the alpha cool and then yours.
    If you look at the Petra one you can see the outlets sizes are way smaller than your which increase flow and presure.
    I guess we'll see what i find but i will also measure with some digital veriner claipers to show it all off
    Xtreme Enthusiast Mekrel's Avatar
    Mar 2005
    0
    Petras top doesn't give both more flow and more pressure.
    If it ain't watercooled, I don't wanna know.
    Apr 2006
    0
    With an 18w DDC
    Max. Head Pressure (at 12V): 8.2 psig (18.91 feet - 5.76m)
    Max. Discharge (at 12V): 4.11 GPM (246.6 GPH - 15.56 LPM/933.5 LPH)
    ^ Petra 01s
    18w DDC
    Maximum Head: 20.2 ft (6.1 m)
    Maximum Discharge: ~ 120 GPH (454 LPH)
    ^ STOCK 18w DDC top
    Goves it more flow with a decent amount of head presure where as this OC lab is just flow flow flow no proesure there at all.
    Mar 2005
    0
    Not according to OC3D when used in a loop it doesn't.
    Which version you talking about? The s version?
    If I were to create a DDC top with the outlet hole the size of a homophobes arsehole with his but cheeks clenched together, which created highest head pressure but killed a load of pumps, would I get a cookie?
  18. #18
    Apr 2006
    0
    If you look at his test to every other there all over the place and the ALphacool for fact does not perform like he says!!!
    Yes i did say 01s but even the 01 does better than the oc lab and alphacool
  19. #19
    May 2005
    Italy(Mantova)
    0
    Pete you can modify pump characteristic(pressure/flow) but it need some choices.
    these choices can make it best or worst top,cheapest or most expensive,nice or similar to the original...
    if you don't know those choice you can discuss around what you think about aesthetic or preview statistics,not discussing regard all project/product spec.
    i suggest you to try what you want,to study what you want and eventually to explain your point of view and your test,but i think you should not explain your conclusion from an image or an absolute value (for example maximum head pressure) reported here because it's not so important to know a point of pump characteristic but i think it's important to know how pump characteristic changes in various real application and that' s impossible to see from actual preview.
  20. #20
    Apr 2006
    0
    Storm need presure not flow
    SO does every other block going
    The OC lab only did well on flow from what i remeber.
    Nice clean simple block it is, just need that twsit but there are other factors which are putting me off ever running it which i don't think Nikos is awear of at all
  21. #21
    May 2005
    Italy(Mantova)
    0
    Pete if maximum head pressure is higher or lower than another top,it does not mean that the pressure will be lower or higher in some application,it depends by pump characteristic...and i think you don't know it because it's not published!
  22. #22
    Mar 2007
    Italy, L'Aquila
    0
    Hello to everyone
    Today we've try all the necessary "crash tests" and I'm happy to say that everything goes OK. The new material has not only seems to be more resistance than the SAN (StireneAcryloNitrile) we've used last time, but has demonstrate that is over three times better. There is absolutely no cracks or risks with this new one, either for the screw holes and the horizontal barb area
    Here is some preproduction pics:
    Kind regards, Nikos
  23. #23
    Xtreme Legend dinos22's Avatar
    Mar 2005
    Australia
    38
    looks nice
    how much are these tops
    Team.AU
    Got tube?
    GIGABYTE Australia
  24. #24
    Sep 2006
    Miami Beach
    0
    from the looks of the geometry of the outlet tube meeting the volute, I get a feeling that the performance will be lacking compared to alphacool/petra
  25. #25
    Xtreme Enthusiast sick_g4m3r's Avatar
    May 2007
    0
    i calculated that to 5.67 feet of head........
    if i am wrong i am sorry, but are you kidding me?
+ Reply to Thread
