+ Reply to Thread
Results 1 to 18 of 18
Thread: P5B Deluxe - How much NB voltage is safe?
    Oct 2006
    California, USA
    0
    I tried searching for information on NB voltage for the P5B Deluxe, but all I could find was a link to an Intel doc saying that 1.35v was about the limit.
    I've been testing my P5B Deluxe and found that I can get it to 400FSB without upping the NB voltage, but then to reach 500FSB I need to increase the voltage to 1.65v
    Has anyone killed their board from too much NB voltage? I'm a bit worried about running it at 1.65v.
    Xtreme Enthusiast Envydia007's Avatar
    Mar 2007
    Killadelphia
    0
    I hope you have adequate cooling for 1.65V because thats high for me.
    CPU: INTEL Q9550 E0 @ 3600 1.28V + CORSAIR H50
    GPU: EVGA GTX 480 @ 725/1450/3800
    PPU: EVGA 9800GTX @ 738/1836/2250
    MB: ASUS P5E X38
    RAM: MUSHKIN 2X2GB
    SOUND: X-FI TITANIUM FATAL1TY | LOGITECH Z-5500 | LOGITECH G35
    HDD: WD 76GB X 2 RAPTORS RAID 0 10KRPM | WD 1TB CAVIAR BLACK 32MB STORAGE
    PSU: CORSAIR HX1000W PSU
    OS: WINDOWS 7 PRO X64 OS
    MON: HANNSPREE 28" 1920X1200 RESOLUTION
    Registered User TeRm's Avatar
    Feb 2007
    Tampa, FL
    0
    I think i killed mine I pushed 1.65v and now she wont post. I was useing massive air cooling too. I guess its time for a p35.
    ASUS P5K Vanilla
    Crucial Ballistix Tracer 2x1 ddr2 1066
    Scythe Infinity
    CORSAIR-520HX
    Feb 2007
    Thailand|ราชอาณาจักรไทย
    0
    I always push it about 1.60-1.65, while benching. And i just put some fan on the NB sink.
    If you can go 1.65, keep going, but just for benching, not 24/7 usage.
    Oct 2006
    California, USA
    0
    ok, thanks. Do you think running 1.45v 24/7 is safe? I know that's outside of Intel's spec, but there's no 1.35v option:/
    Xtreme Member Gam3Ra's Avatar
    Aug 2006
    Bulgaria
    0
    Why you need this big voltages on NB?
    I have 3 P5B-Deluxe motherboards (1.03G C1, firt revision) and for 400FSB (max on 1066 strap from bios) need only 1.25V (stable). Up to 410-420FSB from Clockgen (still 1066 strap) and stable again. In 1333strap 520FSB and 1.25V is still stable, for more I don't have ram.
    I thing more than 1.45V is for biiig benching
    ASUS P5B Deluxe 1.03G (C1) Vdroop penciled [FSB 1.20V, NB 1.25V, SB 1.50V, ICH 1.0V]
    C2D E6400 [L631B #002] @ 3800Mhz 1.391V
    Noctua NH-U12F Lapped
    2x1GB Transcend 667 (Powerchips) @ 950Mhz 4-5-4-15-3-30-10-20-10-20 2.05V
    XFX 7900GS 480M @ 620Mhz/1920Mhz [stock voltages/cooling]
    Sirtec 420W
    Oct 2006
    California, USA
    0
    my board maxes out at ~410FSB at 1.25v, and my E6400 can reach ~415*8 on 1.4vcore. So I need more NB voltage than 1.25v.
    Xtreme Addict ineedaname's Avatar
    May 2006
    Canada
    0
    1.65 is REALLY pushing it.
    I'd say 1.45 is probably the most u should go.
    I run my buddy's P5B Deluxe on 1.45 but i have a good fan on it all the time with reapplied tim.
    CPU: Q6600 @ 3.6ghz G0 Week 37B
    Mobo: Asus P5k Deluxe
    Cooler: TRUE 120 (150cfm Delta)
    2xHR-05
    2xHR-09
    Mem: G.Skill 4x1Gb 6400HZ
    Vid: HIS 4850
    HDD: 80Gb 16mb Cache Raptor
    500Gb 7200.11 Seagate
    PSU: Enermax Noisetaker 600w
    Case: Thermaltake Armor (4x120mm 104CFM Panaflo)
    3dmark06: 16k
    Aug 2006
    The Netherlands, Friesland
    0
    I think this is more a question how much a 965 chipset can handle, so here are my AB9 results (all 1066 strap).
    - I have used 1,45v for the last 7 months, no problem at all.
    - for benchmarking i use 1.7v for around 485fsb and above, no probs at all.
    - for max CPU clocks i use mostly just below 2.0v
    - Max i tried was 2,35v, 510fsb, but board crashed, couldn't use the board for more then one day.
    P5B mostly uses 1333strap when overclocking, so you P5B guys shouldn't worry about 1,5v for 24/7 i think.
    >2500K ES 4.7Ghz 24/7
    >Sabertooth P67 with sucky sucky bios
    >HD4890
    >Cosmos 1000
    >CM Silent Pro M700
    >SSD, Intel X25M G2
    >H2O---MCP655 - XSPC360 - Apogee GT - HWlabs 240 stealth - Fuzion GFX - MCRES.
    Xtreme Guru JoeBar's Avatar
    Aug 2003
    Athens, Greece
    0
    Quote Originally Posted by Gam3Ra View Post
    U need it if u're running async on high fsb's...
    It's all a matter of cooling the nb. I have mine @ 1.65v 24/7 for the past 7 months and i hadn't have a single prob. I'm using Tt's extreme spirit on nb.
    Project ZEUS II
    Asus Rampage II Extreme
    Intel I7 920 D0 3930A @ 4.50GHz (21 X 214mhz)
    3 x 2GB G.Skill Trident 1600 @ 1716MHz (6-8-6-20-1N)
    2 x Asus HD 6870 CrossFire @ 1000/1100MHz
    OCZ Vertex 2 60GB | Intel X25-M 120GB | WD Velociraptor 150GB | Seagate FreeAgent XTreme 1.5TB esata
    Asus Xonar DX | Logitech Z-5500 | LG W2600HP 26" S-IPS LCD
    Watercooling setup:
    1st loop -> Radiator: 2 x ThermoChill PA120.3 | Pump: Laing DDC-3.25 with Alphacool HF 38 top | CPU: Swiftech Apogee XT | Chipset: Swiftech MCW-NBMAX | Tubing: Masterkleer 1/2" UV
    2nd loop -> Radiator: ThermoChill PA120.3 | Pump: Laing DDC-3.2 with Alphacool HF 38 top | GPU: 2 x EK FC-6870 | Tubing: Masterkleer 1/2" UV
    Assembled in Mountain Mods Ascension Trinity
    Powered by Corsair Professional Series Gold AX1200
    Xtreme Addict strange|ife's Avatar
    Dec 2006
    Vegas ,NV
    0
    1.65 is to much imo for daily driver.
    nothing over 1.5 without active or water cooling
    Oct 2006
    California, USA
    0
    Is there any way to check the NB temp, besides using an infrared thermometer or something?
    Xtreme Member xenoasd's Avatar
    May 2007
    Canada
    0
    i have mines at 1.65 for the couple last months.. i just left it, no fan no cooling, just the heatsink.
    E6600 - 3.6Ghz @ 1.4V
    Thermalright Ultra-120 Extreme + S-FLEX SFF21F 120mm Fan
    Asus P5B-Deluxe WiFi-AP
    Crucial Ballistix DDR2-1000 2GB
    eVGA 8800GTS SuperClocked 320MB 650/1900
    Creative X-Fi XtremeMusic
    Corsair HX520W
    Antec 900 Case
    3DMark06 - 13,078
    Feb 2007
    0
    1.45v 24/7 you need an HR-05 or equivalent for your NB. Don't forget a fan, coz it gets hot to touch without one.
    Oct 2006
    California, USA
    0
    ok, thanks. I'll look into getting a new NB heatsink when I buy a new CPU heatsink
    Xtreme 3D Mark Team Staff Kunaak's Avatar
    Nov 2002
    Juneau Alaska
    0
    I been running mine at 1.65 for about what, 6-7 months now... I got mine about a week after they came out. so when ever that was.
    I use 1.85+ for benching and such (vmod of course)
    Jan 2004
    0
    My P35 NB chipest heatsink just barely gets warm with pushing 1.55v through it under load on my Asus P5k deluxe. I have pretty good aircooling on the heatpipes coming off of it so it dissipates the heat pretty fast.
  18. #18
    Oct 2006
    California, USA
    0
    Quote Originally Posted by Kunaak View Post
    Is that with stock cooling on the NB?
+ Reply to Thread
