+ Reply to Thread
Results 1 to 6 of 6
Thread: P5b dlx NB temps
    Mar 2007
    0
    P5b dlx NB temps
    Hi,
    What is the maximum temp of NB, i have it at 68°C , is that ok!!!!
    Xtreme Member mukmaster's Avatar
    Jun 2005
    Oregon , USA
    0
    Ugh that a little hot , But I like to keep mine around 40
    FOLD for XS WCG ; or Rodzilla kills a kitten
    Apr 2007
    0
    How do you check?
    Oct 2004
    0
    Mine is hot enough to touch for long but it's definitely around 40-50C.
    MY HEATWARE
    Asus P5B-Deluxe WIFI/AP motherboard with 0804 bios
    Intel Core 2 Duo E6300 at 3.50Ghz w/ 1.4125(in bios) & 1.35V(under orthos in windows)
    Patriot DDR2-800 (PC2 6400) 2GB @ 500Mhz 2.3V
    ATI X1900 AIW video card
    Seagate 160Gb 8mb SATAII NCQ
    NEC 3550A DVD writer
    OCZ PowerStream 600W SLI
    Fan Master
    Lian-Li PC-7B Plus II Black Midtower
    2 x Gateway FPD2185W 21" LCD Dual monitors
    Klipsch 5.1 Promedia THX speakers system
    Xtreme Addict ineedaname's Avatar
    May 2006
    Canada
    0
    68 is SCORCHING
    like wut mukmaster said keep it below 40 if you can.
    I'd really suggest putting some new tim and fan on the nb
    A HR-05 or thermaltake extreme spirit are good.
    Noctura has some new NB cooler too which looks very promising if u can find it.
    CPU: Q6600 @ 3.6ghz G0 Week 37B
    Mobo: Asus P5k Deluxe
    Cooler: TRUE 120 (150cfm Delta)
    2xHR-05
    2xHR-09
    Mem: G.Skill 4x1Gb 6400HZ
    Vid: HIS 4850
    HDD: 80Gb 16mb Cache Raptor
    500Gb 7200.11 Seagate
    PSU: Enermax Noisetaker 600w
    Case: Thermaltake Armor (4x120mm 104CFM Panaflo)
    3dmark06: 16k
    Mar 2007
    0
    Quote Originally Posted by The Brick View Post
    How do you check?
    I am using a thermometer, it shows 65°C to 68°C. Everest shows:
    motherboard temp : 28°C is it the temp of the NB? if yes, why my thermometer shows 68°C?
+ Reply to Thread
