Page 1 of 2 12 LastLast
Results 1 to 25 of 34
Thread: BIOSTAR TA690G AM2 OC experience
    Nov 2004
    Nov 2004
    BIOS
    Xtreme Cruncher
    Oct 2004
    Germany, near Stuttgart
    seems like a solid board...
    E2160 @ 360x9, max 390x9 watercooled
    GA-P35-DS3
    Cellshock D9GMH @ 545mhz cl5-5-5-5-15
    Palit 7300gt 500/1000 @ 780/1600 watercooled
    Nov 2004
    Test platform
    CPU:AMD AM2 Athlon64 X2 3600+
    MB: BIOSTAR TA690G AM2
    DRAM:CORSAIR TWIN2X2048-10000C5DF
    VGA:ATI Radeon Xpress 1250
    HD:Seagate 7200.10 320GB
    POWER:Corsair HX620W Modular Power Supply
    Cooler:TT Big Typhoon VX
    VGA
    3DMARK2003
    3DMARK2005
    3DMARK2006
    345Mhz PI 32M
    Mar 2006
    nice review..
    my result with:
    CPU:AMD AM2 Athlon64 3500+ & Sempron64 3000+
    DRAM:Hynix FP-C4 2 x 256Mb PC4300
    HD:Seagate 7200.10 160GB
    POWER:Enlight 300watt
    Cooler:Stock cooling
    Sorry for my bad english
    Xtreme Mentor
    Sep 2005
    Netherlands
    seen pics ofit this week.
    nice layout price of 80 euro overhere is also nice.
    but how do the 2 heatsinks feel? are they hot or ok temp?
    Time flies like an arrow. Fruit flies like a banana.
    Groucho Marx
    i know my grammar sux so stop hitting me
    Jan 2004
    wow ...326+ stable...
    I was considering buying this mobo until I read a review over at VR-Zone and I was disappointed by oc results
    "My only gripe about the board: despite having all the tweaking options available in the BIOS, the board can barely overclock. Even after I plop in a better cooler like the Scythe Mine with a 120mm fan, the board still refuses to budge even 5Mhz off stock HTT. Honestly speaking, I wouldn't expect this board to fare too well in overclocking as it's not the main purpose the board's designed for in the first place.."
    http://sg.vr-zone.com/?i=4726&s=10
    I may reconsider now...
    Athlon 64 X2 5200+ || Gigabyte GA-MA69GM-S2H || Connect3d 4850 || Crucial ddr2-800 Lanfest 2x1 Gb || AKASA PowerPlus 650W || Watercooled
    AthlonXP-M 2500+ @2500 || Abit NF7-S v2.0 || ATI 9700 PRO || Corsair XMS PC3500 v1.1 2x256 + 1x512 Kingston HX || Enermax EG465P-VE FC || Slk 900A - Delta 92mm
    Jun 2005
    Bangalore,India
    I also have this board?Can you tell me the BIOS version u r using as the options in mine looks bit diff....dont have that CPU multi & Vid in Ocing section
    Xtreme X.I.P.
    Apr 2005
    Thanks WWM for sharing
    This board probably has the best layout and components of all 690G mobos
    Mar 2006
    Quote Originally Posted by Starscream View Post
    temp of 2 chipset is ok! R690 is around 45c and rd600 around 25-30c
    im using 427 bios version download form china website..but there still any bug on vdimm voltage,,
    -1.95=195volt(default)
    -2.05=2.04volt
    -2.15=2.15volt
    -2.25=2.24volt
    -2.35=1.95volt ( not work at this voltage)
    -2.45=2.45volt ( work but shutdown first)
    -2.55=2.54volt ( work but shutdown first and coolboot with micron chipset)
    -2.65=not tested
    May 2005
    [EU] Latvia, Jelgava
    So, you can overclock IGP straight from BIOS?
    Nov 2006
    which shop ?
    Xtreme Legend
    Jun 2002
    Helsinki, Finland
    Some results from my 690G tests a while ago (reference board):
    2k1:
    CompareURL
    10k with IGP!
    3DMark05:
    CompareURL
    Nov 2004
    Quote Originally Posted by Kasparz View Post
    I dont try it...
    Xtreme Mentor
    Sep 2005
    Netherlands
    Quote Originally Posted by Trunks View Post
    which shop ?
    german shop.
    http://geizhals.at/deutschland/a256765.html
    Groucho Marx
    Xtreme Mentor
    Apr 2005
    Question
    Quote Originally Posted by macci View Post
    macci, could this Sapphire pull out same result:
    http://www.sapphiretech.com/se/produ...gpid=178&grp=6
    There shouldn't be a much difference among reference mobo and this pure innovation?!
    Xtreme Legend
    Jun 2002
    Helsinki, Finland
    Nedjo, quite possibly it could do that. Those scores were nothing special really for 690 - another board I tested earlier would run up to around 370MHz X5 HT Link mode (over 1.8GHz HT Link).
    The Sapphire board is actually quite a bit different from the ref. design.
  18. #18
    Xtreme Mentor
    Apr 2005
    Problem of the Sapphire boards is that they have really bad BIOS support. it takes them way to long to make changes and fixes. Silently I was hoping that pure innovation and reference mobo are identical so that I could use refenrece BIOS.
    One problem with biostar is that with TwinMOS PC2-6800 didn't wanted to change Tcl from 4 to 5. I t kind a limits the overclock for the memory.
  19. #19
    Jan 2003
    Scotland
    Windwithme could you let us know what bios version you used please ?
    This might be a X2 4000 Brisbane issue, but I don't get any half cpu multi's to select when setting it manually, just whole numbers up to 11 oddly enough considering the cpu's max is x10.5.
    This is using the 516 bios. Trying to set the cpu multi manually in the 427 bios causes the board to not post.
    Edit : After a bit of tweaking, I can now select cpu multi's in the 427 bios. Still can't see half multi's though.
    Regards,
    ALan
  20. #20
    Xtreme Cruncher
    May 2007
    what bios are all of you TA690G users running
  21. #21
    Jan 2003
    Scotland
    I'm running the 427 bios from the Chinese website, as the later ones don't allow manual ram timings :
    http://www.biostar.cn/supports/BIOS....D=26&Value=551
    Regards,
    ALan
  22. #22
    Jan 2007
    Brisbane, Australia
    I feel like putting a filter on the word BIOSTAR so I don't have to read all this stuff about boards we can't get here
    This country sucks for MB variety
  23. #23
    May 2006
    USA
    How are you guys increasing CPU coltage? The Bios shot shows up to 1.35. Are you guys using Crystal CPU or something similar?
  24. #24
    May 2006
    USA
    There r 2 more bios after 427 on that page.
    I'm buying this board right now.
  25. #25
    Apr 2006
    can you guys confirm that you need a floppy drive to flash the bios in this board because it doesn't have a windows flash program? I am building a mATX system for someone and don't plan on putting a floppy in it. thanks.
    Gigabyte MA790FX DS5 - 5000BE AM2 (3.1)
    Asus 6850 - Crucial Balistix 5-5-5-24
    Corsair 550 PSU Zalman 7000Al Cu
