Page 1 of 2 12 LastLast
Results 1 to 25 of 27
Thread: different types of cooling methods
    hwbot crew
    Jun 2002
    Belgium!
    Due to large request, we're adding the ability to specify the cooling used on your processor / videocard / motherboard / memory.
    I'm not really up to date about which kinds of cooling methods are getting used nowadays. Is this list complete (or can I drop one)?
    'stock cooling'
    'air'
    'water'
    'peltier'
    'dry ice'
    'phase change: simple'
    'phase change: cascade'
    'phase change: rotary'
    'liquid nitrogen'
    Of course, there are a few exceptions like using DI in a watercooling container, or rotary cascades etc, but the smaller the list the easier it is to use.
    Should we make a difference between air cooled and water cooled peltiers? Or are air cooled peltiers virtually non existent nowadays?
    Do we need to make a difference between all the different kinds of phase changes (simpe, cascade, rotary, etc), or just put them in one category 'phase change'?
    Should you be able to select the manufacturer and/or model of your cooling, or is this useless info?
    HTPC (win xp): Turion MT-30 @ 2Ghz | NF4 | XFX 7900GT | 26" TFT
    Development (mac osx): Macbook Pro | Core Duo 1.86Ghz | 1.5GB DDR2
    Wanna look under my kilt?
    Jun 2005
    Glasgow-ish U.K.
    What about air-con air?
    Thanks for adding this option
    you sigged that?
    why?
    ______
    hwbot crew
    Jun 2002
    Belgium!
    Airconditioned air? I'd be hard to split up the air cooling methods, as the effect differs greatly based on the climate you live in...
    Jun 2005
    Glasgow-ish U.K.
    True. I guess theres always gonna be a fairly large temperature range even in the categories...
    Vapo XE II Vs an SC11 SS
    2-stage Vs 3-stage cascade etc
    Still very happy to see the option!
    you sigged that?
    why?
    ______
    One-Eyed Killing Machine
    Sep 2006
    Inside a pot
    Stock Cooling
    Air Cooling
    Water Cooling
    Single Stage
    Cascade
    Rotary
    Dry Ice
    LN2
    Peltier
    should be good enough
    Coding 24/7... Limited forums/PMs time.
    -Justice isn't blind, Justice is ashamed.
    Many thanks to: Sue Wu, Yiwen Lin, Steven Kuo, Crystal Chen, Vivian Lien, Joe Chan, Sascha Krohn, Joe James, Dan Snyder, Amy Deng, Jack Peterson, Hank Peng, Mafalda Cogliani, Olivia Lee, Marta Piccoli, Mike Clements, Alex Ruedinger, Oliver Baltuch, Korinna Dieck, Steffen Eisentein, Francois Piednoel, Tanja Markovic, Cyril Pelupessy (R.I.P. ), Juan J. Guerrero
    hwbot crew
    Jun 2002
    Belgium!
    So, group peltier in one category, and split up phase change into 3: single, cascade, rotary.
    Sounds good to me.
    hwbot crew
    Jun 2002
    Belgium!
    Is keeping track of cooling used on the memory sticks useful?
    Memory Addict
    Aug 2002
    Brisbane, Australia
    Quote Originally Posted by RichBa5tard View Post
    i'd say yes.. but i'm just addicted to memory LOL :o
    Jun 2005
    Glasgow-ish U.K.
    If you're not joking, i`d rather see GPU cooling method implemented before RAM cooling
    you sigged that?
    why?
    ______
    Aug 2006
    bong
    oc: 3.9!!!!, but back to 2.4 (stock) for longevity
    1 gig ocz gold ddr 800.
    my rig: p5b deluxe wifi, 600 psu, 7900GT KO, e6600, water cooling, and thermalright nb cooler.
    my css name: theonemuffintorulethemall
    hwbot crew
    Jun 2002
    Belgium!
    @K404: they will all be released in the same update.
    bong, are ppl actually still using this?
    Xtreme Cruncher
    Dec 2006
    Palo Alto, CA
    Bong cooling IS watercooling...water temps won't get much below ambient.
    Lenovo Thinkpad X220 - Core i5 2410m, 4gb
    waiting on 28nm video cards...
    hwbot crew
    Jun 2002
    Belgium!
    Afaik very few people use bong cooling. Those who do can select 'water cooling' and type 'bong cooled' in the description. ; )
    Jul 2002
    [M] - Belgium
    yes that's good enough
    Belgium's #1 Hardware Review Site and OC-Team!
    Xtreme Cruncher
    Jan 2006
    Cornwall, UK
    could you do it via temperature rather than hardware used? As someone living in siberia can obviously get as good temps on air as those with weak phase units. . However if this is simply to help the description and not being used for new points and categories what you have is fine.
    hwbot crew
    Jun 2002
    Belgium!
    @melymel2789: it's purely informational, as we have no way to verify. No ranking / points will be assigned.
    xtreme energy
    Oct 2004
    Europe, Latvia
    Perhaps ambient should be specified as well, it will pretty much say the difference between -20C air and + 30C air
  18. #18
    Sep 2006
    Inside a pot
    I concur
    If you bother into re-coding the submission page to add the cooling used textbox/drop-down menu, add a textbox to report the ambient temp
  19. #19
    Diablo 3! Who's Excited?
    May 2005
    Boulder, Colorado
    Is there a reason why "rotary" is a being considered a different form of phase change cooling compared to a single stage? I'd say Single Stage, Autocascade, Cascade would be more clear as there are rotary powered single-stages, rotary powered autocascades, and rotary cascades, along with hermetic alternatives also. Even simpler would be single-stage or multi-stage with autocascade falling under multi-stage.
  20. #20
    Sep 2006
    Inside a pot
    To separate the Single Stage from Single Stage using Rotary's cooling-wise
  21. #21
    hwbot crew
    Jun 2002
    Belgium!
    so, instead of:
    This would be better?
    Sorry, I'm not really into this phase change cooling.
    Adding ambient temps is not really a problem, but I don't want to clutter the submission page too much either.
  22. #22
    xtreme energy
    Oct 2004
    Europe, Latvia
    Nothing else is required, just ambient temps and type of cooling Actually ambient temps are more important only for water/air cooling.
  23. #23
    hwbot crew
    Jun 2002
    Belgium!
    True, but I think most people don't know the exact ambient temp.
    Maybe we should divide ambient into ranges?
    'arctic: <10C'
    'freezing: -10 to 0C'
    'cold: 0 to 10C'
    'chilly: 10 to 15C'
    'normal: 15 to 25C'
    'warm: 25 to 30C'
    'tropic: >30C'
  24. #24
    Sep 2006
    Inside a pot
    How 'bout this:
    Cooling:
    Stock
    Air Cooling
    WaterCooling
    Phase Change: Single
    Phase Change: Single Rotary
    Cascade
    TEC ( Peltier )
    Dry Ice
    LN2
    Ambient Temp Ranges:
    -15C to 0C
    0C to 10C
    10C to 15C
    15C to 20C
    25C to 30C
    30C+
  25. #25
    Feb 2005
    Belgium
    Simple method: air, water, xtreme and a textfield called: descibe.
    Though, if you're looking for implementing it into the search engine people might like to have more detailed search options.
    Something like this:
    - Stock Cooling delete, replace with Air Cooling (I would not use stock cooling as an option as it is of very few interest, most people mod it anyway somehow and you must also not forget that there are factory watercooled videocards out there which might confuse people in what box they have to mark)
    - Water Cooling
    - TEC/Peltier, Waterchiller
    - Single Stage
    - Dry Ice
    - Multi Stage (Cascade, autocascade, etc)
    - LN2
    And eventually add an extra describe field...
    'arctic: <10C'
    'cold: 0 to 10C'
    'chilly: 10 to 15C'
    'normal: 15 to 25C'
    'warm: 25 to 30C'
    'tropic: >30C'
    sounds nice!
