Results 1 to 22 of 22
Thread: 2* Heatercore (Dangerden) or 1* BIX2
    Jun 2003
    Belgium / Antwerp
    well I might get myself a Watercooling Setup one of these days and I was wondering:
    should i buy:
    1 * Black Ice Extreme 2 (Dangerden)
    or
    2 * Heatercores (Dangerden) and put those 2 in "serie" (dunno if this is the right word in english :p)
    my first guess is that 2 rads will outperform 1 rad but i'm totally not sure ...
    can neone confirm or disconfirm this ?
    Pentium 4 1.6 @ 2.5 Watercooled
    Gigabyte GA-8INXP
    2*256 Corsair PC 3200 CAS 2 Dual Channel
    Asus Geforce 4 Ti 4400
    Soundblaster Live 5.1
    Western Digital 120 GB 8mb cache / 7200 rpm
    Western Digital 60 GB 2mb cache / 7200 rpm
    Jan 2003
    NE Pennsylvania
    2 heatercores.. I'm just a watercooling n00b but word on the street is that heatercores generally outperform black ice extremes by quite a bit... not sure about the BIX2 though
    AMD Phenom II 1090T @ 4GHz
    MSI 890FXA-GD70
    4GB G.Skill PI DDR3 1600 C6
    OCZ Agility 2 60GB
    Visiontek Radeon 5850
    Antec Nine Hundred
    Watercooling:
    Enzotech Sapphire Rev.A
    Swiftech MCW80 + 5850 heatsink
    Swiftech MCP655
    Swiftech MCR320
    Jun 2003
    Belgium / Antwerp
    yup i wanna know if it outperforms BIX2 too
    cos 1 BIX2 costs 102$
    and 2 Heatcores cost 80$
    so .....
    i'm sure that 1 BIX2 outperforms 1 Heatercore
    but do 2 Heatercores outperform 1 BIX2
    Gigabyte GA-8INXP
    Jun 2003
    Belgium / Antwerp
    oh and i forgot to ask:
    how can i best attach an 120 mm fan to the heatercore ?
    i know there are fanducts, fabricated by Dangerden itself, but it takes away 25% of the airflow and that's just plain stupid ....
    Gigabyte GA-8INXP
    Jan 2003
    canada
    http://www.dtekcustoms.com/subcatmfg...1=228&2=-1&6=1
    this is one of the best Heater core you can buy for W/C IMO
    or you can also get a car heater core
    I dont know how much they are in Belgium but I'm sure you'll save some money
    AMD AthlonXP 2400+@14X166
    Asus A7V333
    ATI Radeon9700pro
    Performance Cooled by D-Tek & Danger Den
    Feb 2003
    Phoenix, AZ
    The Dtek heatercore is brand new (unpainted) with shroud and mounting hardware. $25 shipped
    * I used this Rad for 3 days to test, brand new, clean, and perfect condition.
    Accept Paypal.
    Sproket
    email me also
    sproket@prowestfilms.com
    8RDA+ w/ 2100+ AIUHB
    WhiteWater cooled
    2x256 TwinMos w/ Winbond @ 205FSB in Sync : 2,2,2,4
    Jun 2003
    Belgium / Antwerp
    well, we're having a kind of "group purchase" (dont know the correct english word) @ Dangerden
    so all of the goods are shipped to one of my mates and that we everyone splits the costs for FedEx and all, you know
    so i'll most likely go for and all Dangerden setup...
    and Sproket, how long will it take to get your rad here in belgium ?
    and how much will it cost in total ?
    Gigabyte GA-8INXP
    Jun 2003
    Belgium Moes City
    little question
    The_LoserKid, you sound like Solid
    whatever I asked Sproket too in his other topic if he ship to Belgium europe too ?
    The_LoserKid, if ya want it..its yours
    maybe Sproket can arrange it as a gift to press taxes below
    BTW D-Tek heathercores rule indeed
    Feb 2003
    Phoenix, AZ
    I just sold heatercore.....SOLD
    WhiteWater cooled
    Nov 2002
    I would not buy a heatercore from the us when u can get one from a local carparts store. I have the bix2, but i'm in the process of setting it up.
    xp2100+@2550mhz 2.03v 210fsb
    Abit nf7-s v1.2
    ATI R9700
    2x512mb Cprsair pc3500 c2
    Dual Channel!!!!!WOOT
    SATA raid on 80gig maxtors
    highest 3dmark 19300
    3dmark2k1
    Feb 2003
    Phoenix, AZ
    yes you can buy a heatercore from Auto parts store BUT they are not as small as Dtek's (the ones in stock) and you will need to make your own shroud.
    WhiteWater cooled
    Nov 2002
    Mi. U.S.A.
    The BIX2 can be beaten by a single heater core.
    Go to:
    www.leakycar.com
    Check out core number 2-342 This is a large core that can take two 120mm fans on one side just as the BIX2 can. But the heater core is both thicker and, more important, it's a single pass design. You will have to cut off the extra tubing the core comes with, but that is no big deal. Will also need to make a custom shroud for this core. Not hard to do out of plexi. This core offers extremly low flow resistence. It costs around $30 at local Napa stores. I don't know what it would cost to ship to EU however. Would still be cheaper than a BIX2 though.
    There are a number of even larger heater cores than this one that can also leave the BIX2 trailing in performance. The above is just the best performing for it's size.
    Feb 2003
    Phoenix, AZ
    About core number 2-342....................??
    Can you run UV dye through it without it acting like a trap?
    Alot of heatercores act as a UV dye filter or trap.
    The UV dye gets trapped in the bottom tank b/c its heavier than water thus turning your green/ or whatever color solution back to water.
    Hmmmmmmmmm??????????????
    Be careful out there if you want to use UV Dye in system!
    I learned the hard way.....I was always wondering where all my UV dye was going. I know others have experienced this also.
    Also if you see your tubing turning white inside its B/C of your RAD/Heatercore!!!! Heatercores are built with soldier inside also, MORE Mixed metal to add to your water cooling system.
    I use an AquaCoil II NOW.
    No UV Dye trap anymore.
    WhiteWater cooled
    Jun 2003
    Belgium / Antwerp
    little question
    well, i'm not
    i just wanna buy one too and since solid didn't post it here, i did
    but i'm gonna buy the BIX2, its practically as good as all the other heatercores AND it has mounting holes so ...
    case closed
    Gigabyte GA-8INXP
    Nov 2002
    Mi. U.S.A.
    I don't know how the UV dye would act in the 2-342 core. As it's single pass it might help, but I havn't done it. First I'd heard of this happening.
    Heater cores arn't what turns your lines white.
    Water wetter does that for you, it builds up a coating on the inside of your system. Beleive it or not this is what it is supposed to do, in part.
    Jun 2003
    ATLANTA! We don't call it georgia.
    86 chevette heater core and Wetwilly's shroud for a whopping total of $26. best way to go, preforms better than any rad/shroud out there. cheap and easy.
    Originally posted by CircuitBreaker8
    So I asked myself, is OCing the videocard really worth it?
    Feb 2003
    Phoenix, AZ
    Craig:
    I know that WW can turn your lines white and that what it does.
    But my lines turned white without anything else besides distilled water. And my UV Dye was trapped in the Heatercore also. Many people see there lines turned white and UV dye disappear in 24 hours over at Procooling Forum.
    Just my experience.
    Funny how I tried 2 different Heatercore's and both acted the same, then I tried an AquaCoil II and everything is just fine. Water is as clear as the day I put it in.
    Also I took the heatercore out of the loop and everything was fine, soon as I added heatercore to loop same problems. It was for sure the heatercore adding problems.
    Now if a cool cpu is all you want then a heatercore is your best bet, but if you do UV Dye and want that clear clean tubing look then your best to go with a Copper Coil type of Rad.
    AquaCoil II
    DangerDen Cube
    2 Maxxpert's
    etc
    I have yet to try a DangerDen heatercore, they have a much smaller tank at bottom and maybe NOT a trap.
    I have seen many people w/ success of UV Dye and DD Heatercore.
    WhiteWater cooled
  18. #18
    Jun 2003
    copper coil rads are horrible. they hinder preformance down to just above aircooling levels. don't touch a copper coil. Make sure you clean out your heatercore realy well before putting it in. Plus it realy doesn't matter if your tubing goes a little white. btw what type of tubing are you using?
  19. #19
    Feb 2003
    Phoenix, AZ
    I use clearflex tubing and have tried Tygon also.
    My Aquacoil II is only 3 degree difference than my Dtek heatercore.
    WhiteWater cooled
  20. #20
    Nov 2002
    California
    I had a BIX2 and a regular heater core both running on my old T.E.C. system and the BIX2 was twice as good...you should of seen the heat that sucker pulled out
    Abit IC7 @300FSB Bios 28
    P4 2.4C@3.6Ghz
    ATI 9700 Pro @ 445/710 Vgpu modded
    Corsair XMS PC 3500 256mb x2
    Liteon 52x24x52 CDRW
    WD 40GB 7200RPM x2
    Enermax EG465P-VE(FCA)
    Chevy Chevette Heater Core
    MCW50-T
    Eheim 1048
    Prometeia Mach I
    Lian Li PC65B
  21. #21
    Jun 2003
    It depends on your core. If you use a bigger one you will destroy the bix without a doubt.
  22. #22
    Nov 2002
    California
    I was using a shrouded Chevy Chevette Heater Core...well still using it since only cooling my GPU with a pelt now...and mabe the NB soon to come ..........its a good heatercore but couldn't match the amount of air the bix could pull threw it...the heatercore was more restrictive, as the bix could just pull that air threw it
    P4 2.4C@3.6Ghz
    WD 40GB 7200RPM x2
    MCW50-T
    Eheim 1048
    Prometeia Mach I
    Lian Li PC65B
