I have been trying to find some pics of these 2 waterblocks in a setup...anybody have some pics using these 2 items?
750W Thermaltake Modular PSU
DFI UT X58-T3eH8
Core i7 920 @ 20 X 200 1.325V
CORSAIR XMS3 DHX 4GB (2 x 2GB) DDR3 1600
768 MB EVGA 8800GTX
1 X 36GB WD Raptor
2 X 150GB WD RAPTORS
1 X SpinPoint P Series SP2504C 250GB
1 X Maxtor 6L300S0 300GB
16 X NEC DVD Burner
7 120mm Yate Loon LED Intake Fan
4 120MM Yate Loon Exhaust Fan
28" HANNSPREE Monitor
Watercooling Loop:
1 X PA120.3
1 X PA120.2
2 X Laing DDC's w/EK-DDC Dual Turbo Top
7 X Yate Loon Blue LED Intake Fans
4 X Yate Loon Blue LED Exhaust Fans
1 X Swiftech GTZ
1 X GPU EK Fullcover Waterblock
1 X XSPC Dual Bay Reservoir 5.25" with Bubble Window
you wanna know if it's doable ???? if so the answer is yes. but you will also need some sort of other cooling method to cool the SB if you do decide to water cool the NB...
Evga X58 sli under cascade
http://www.xtremesystems.org/forums/...d.php?t=219788
Evga X58 Sli ultimate overclocking/ overview/ discussion thread
http://www.xtremesystems.org/forums/...d.php?t=221082
proud owner of E8600 Q822A435
As requested: this is mine
shockingly enough, the flattened tubes dont really inhibit flow. i testeed for that a while back and found that it doesnt effect flow. I suppose the reason for this is that the tubing will deform it shape but stil have the same cross-sectionaly volume which makes the flow the same.
that said, having a tube flattened out like that, may, over time cause it to collapse.
