+ Reply to Thread
Results 1 to 3 of 3
Thread: What does it sound like when a head hits the disk?
    The Voice of Reason Soulburner's Avatar
    Oct 2003
    Lincoln, NE
    0
    Is it sort of a quick metallic screech? If so, our Dell E1505 is about to bite the dust...it started doing this today sporadically. WD Diagnostics failed both the quick and extended tests saying there are bad sectors that could possibly be repaired but the data would be lost. Haven't gotten any sort of warning from the SMART monitoring though.
    I'm backing up the whole computer now and I will try to repair the sectors after, but this doesn't look good
    Just for reference it uses a SAMSUNG 60gb drive. I actually like this drive because its no slouch for a laptop and its extremely quiet, this notebook doesn't "crunch" at all compared to most laptops that I have used.
    Windows 7 + SSD:
    Mode: AHCI, default Microsoft driver or latest Intel RST
    Defrag: Off
    Hibernation: Off (use Sleep mode, recommend a UPS)
    Indexing: On (it only indexes a few locations, not your whole system unless you tell it to)
    Page File: On (set to the minimum of 16MB if you have a large amount of RAM, disabling not recommended)
    Prefetch: On
    Superfetch: On (RAM is always faster than an SSD - use it)
    System Restore: Off (with regular backups)
    Browser Cache: RAM Only, Disk Cache Off (How to with Chrome)
    Documents, Music, Pictures, Videos, Downloads to HDD (Public Libraries too, see above link about junctions)
    UAC: On!
    Xtremely High Voltage Sparky's Avatar
    Mar 2006
    Ohio, USA
    44
    Why are you using WD tools on a samsung drive?
    A metallic screech strikes me as a head crash, that is what an induced head crash was like when I was playing with an old 1GB drive I had opened up. I'd get your data off it and RMA the drive. SMART is stupid really, told me a drive was fine when it obviously had the click of death and had totally dumped half the data on the drive.
    The Cardboard Master
    And put that GPU to work too! Fold for XS
    Main PC: Intel Core-i7 2600k @ 4.5GHz, 8GB DDR3-1600, Radeon 7950 @ 1000/1250, Win 7 Pro x64, water - ONLINE
    Office PC: Intel C2D e8400 @ 3.0GHz, 4GB DDR2-800, GeForce GTS 250, Win 7 Pro x64, air - ONLINE
    Dedicated: DP Intel Xeon LV Sossaman @ 2GHz, 4GB DDR2-400 ECC, Win XP Pro, air - ONLINE
    Family PC: Intel C2D e8500 @ 3.2GHz, 3GB DDR2-667, Radeon X1300, Win 7 Home x64, air - ONLINE
    Oct 2003
    Lincoln, NE
    0
    Yeah, I have never heard it before but when I did, it immediately set an alarm in my head and that is the first thing I thought of. I got out the 500gb MyBook immediately. She does have 1 year warranty on this notebook I believe and she got it in October so we should be ok and hopefully I can prevent my girlfriend from losing any data.
    It shouldn't matter who makes the drive, its a hard disk scanning/diagnostic tool.
    Windows 7 + SSD:
    Defrag: Off
    Prefetch: On
    UAC: On!
+ Reply to Thread
