Low pressure was around 10psi or so at full load. The pressure didn't really match up to the temp, or it would have been much colder, but I think that the LS head is the main reason for it.
Hey Ron
Compressor over here is 8.5CLX danfoss so larger displacement, but about the same performance. Same idea to the NL11 vs NF9 I guess.
Gas was the 404/402 blend I've been working with. I don't get the same mix twice, but I don't really want to. Every system behaves just a little diferent so i just charge how it seems to like it best. I think I had a larger % of 402 this time, the cooler just seemed to like it, probably 70/30 of 402/404.
The stock VapoLS accumulator is pretty large so it was easy to deal with the high load tuning. About 5" long and maybe 1.25" diameter? Something like that.
Yes, the LS uses .028" or a really close metric equivelent. I was tempted to change things to .031" but it's not so easy on the LS line. .028" can be used for high load, but it's easier to do it with .031" imo.
It was nice to see it running with good charge but not flooding back at all. I feel that's necessary to behonest. If you get floodback issues it can leak to compressor failure over time so ensuring it's charged right means you get the best life out of the system, and you can still use it with lower loads without fear.
Glad you guys think it's ok
Gray
