Results 1 to 23 of 23
Thread: 8800GTX in a Super Lanboy - Xpost from OC forums
    Jul 2006
    Greetings Guys,
    This has been a long time coming, I decided to break down and get some new drill bits and just freaking do it.
    I went out and got an 8800GTX due to my 6800GS getting sold locally here, i didn't want to toss either of my Super Lanboys because of a stupid 1" of 8800GTX pwnage not letting me get the thing in the case.
    Took me about 5 hours from teardown to power on.
    It was pretty clean in there before i guess, the biggest problem was the 4 hard drives that form my 2 RAID 0 arrays. Notice the Jaton MX440 twin head PCI video card in there Yeah, i wasn't gaming for like... a week.
    Some after market sinkage, loaned the stockers to a friend so he could RMA his board... still a work in progress, i know my northbridge isn't going to win any pretty points... but it works
    Grill cutting for airflow .. The super lanboy cuts like BUTTER :P Entire drive cage is out there is SOOOOOO much room in this case without it.
    After about an hour of measuring and dry fitting, it looked like the seagate raid array i had going would fit at the bottom of the case ( TIGHT fit ) and the WD raid 0 array would fit up top in the 2 5 1/4 bays that i wasn't using. Notice how close they are to the end of my Audigy ...The seagates are on short brass standoffs, and are mounted using some freshly drilled holes in the bottom of the case.
    Better look at the bottom, i wish i could have used some of the holes from the recently extracted drive case, but none of them lined up.
    Zero room to work with cables. i had to use the reverse upsidedown sata cables and a double sata to single molex adaptor in order to properly connect the drives and not break anything. At least the standoffs the hard drives are sitting on provided a space to stuff cables
    Started wiring everything back up. Out of everything i had done up to this point, this took the longest and took the most out of me.
    OMG... almost done! 8800GTX is in, and starting to look pretty :P
    ( cont. )
    |Main Rig:
    |CPU: Bloomfield i7-965ES
    |Cooler: Scythe Ninja2 w/ clip kit
    |Mobo: P6T Deluxe
    |RAM: 6gb Crappy Kingston KVR1333D3N9 for now
    |VID: 2x 8800GTX SLI
    |PSU: Neo HE 500w
    |CASE: Antec 902
    Jul 2006
    Continued from post #1:
    DONE... finally. I took a nap for a few hours after this and came back to it. I'm still not 100% happy with the wiring up top... there is still a big knot there... but less pronounced now.
    Picture of the Ninja lit up with the lights on
    Lights off! my apologies for the blurry last pic, it was the best i could do with the crappy cam i've got.
    Here is a pic of what i removed from the case. I might use this and the other drive cage thats in the other super lanboy for a really nutty picoBTX NAS enclosure. both cages look pretty good and they look like they would lend themselves pretty well to that
    Some questions were raised over at OCF on whether/not it was safe to have the HDDs just bolted to the bottom of the case on standoffs... after reading all the posts i decided that it was best to have them insulated... pics:
    Thanks for the look
    ~ Gos
    |Main Rig:
    |Mobo: P6T Deluxe
    |VID: 2x 8800GTX SLI
    |PSU: Neo HE 500w
    |CASE: Antec 902
    Jan 2005
    Looks clean, nice job!
    Dec 2005
    What is this zalman on nb? He must have cooler on stock? or passive works but you wanted for the "quiet" the spire cooler?
    Jun 2005
    Oregon , USA
    Dude that look realy clean. make sure to shock mount the hard drives .
    BTW I cant tell if they are but it looks like there bolted into the case.
    Nice work gos
    FOLD for XS WCG ; or Rodzilla kills a kitten
    Jul 2006
    bump! updated as promised.
    Quote Originally Posted by Soker View Post
    The little Zalman flower thing worried me for passive chipset cooling, so i ghetto strapped a spire 40mm fan to it until i can get something better. She seems to do pretty well
    Further plans on the case include a custom front facia thing, probably out of some aluminum stock from Lowes, and a glass black paint job on the inside and out. I may also change out the plastic side windows with regular acrylic and do a slight tint on them. Case lighting will also be changed to red once the paint job happens.
    ~ Gos
    |Main Rig:
    |Mobo: P6T Deluxe
    |VID: 2x 8800GTX SLI
    |PSU: Neo HE 500w
    |CASE: Antec 902
    Egyptian OverClocker
    Mar 2005
    Cairo, Egypt
    very nice idea for ur hdd
    Soon to be :
    ASUS P8P67 Deluxe, Intel SB i7-2600k, G.Skill Rj-X F3-12800CL6D-4GBXH, MSI HD6950 2GB, Corsair 750AX, Intel 80GB G2 SSD, DELL U2410
    Used to be: SaFrOuT
    Sep 2006
    Hauppauge, NY
    dood how do you get your ninja to lite up like that ?
    is that a cathode in there?
    Abit Fatal1ty F-I90HD mATX w/ HDMI
    Intel Core 2 Quad Q6600 SLACR/G0
    Buffalo Firestix 2x1GB DDR2-1000
    Razer Barracuda AC-1
    Apevia X-Qpack2 Black & 420w PSU
    Stock Intel HS w/ 92mm fan
    Jul 2006
    Quote Originally Posted by cursivearmy1 View Post
    Yup It was a test to see if the 4" CCFL would dit, haven't gotten around to taking it out.
    I was thinking that a string of bright LEDs would be less of a fire hazzard though.
    ~ Gos
    |Main Rig:
    |Mobo: P6T Deluxe
    |VID: 2x 8800GTX SLI
    |PSU: Neo HE 500w
    |CASE: Antec 902
    The un-extreme XIP
    Jul 2004
    lol, ccfl in the heatsink. looks pretty cool imo.
    the nice thing about this mod is that you can mount the HDD cage back with a few nuts and bolts when you get a shorter vid card
    i5 3570K@ 4.8GHz 1.32v, 32GB Gskill 1866, Gigabyte g1 sniper m3
    HD7970@1125/1575 stock voltage
    1TB F1+2*128GB Crucial M4
    Silverstone 450w, no case
    2560*1440@120Hz overclocked catleap
    Steelseries G6v2+5600dpi modded logitech trackball
    I am Xtreme
    Oct 2005
    Grande Prairie, AB, CAN
    Do you find the case flimsy without the drive cage? When i had the SLB and removed the cage, it wobbled pretty badly.
    Nov 2004
    Quote Originally Posted by lowfat View Post
    I always thought the case was flimsy from the start. Its partially why when I decided to go back to air cooling I went with the non-super lanboy which feels far sturdier.
    NZXT Tempest | Corsair 1000W
    Creative X-FI Titanium Fatal1ty Pro
    Intel i7 2500K Corsair H100
    PNY GTX 470 SLi (700 / 1400 / 1731 / 950mv)
    Asus P8Z68-V Pro
    Kingston HyperX PC3-10700 (4x4096MB)(9-9-9-28 @ 1600mhz @ 1.5v)
    Heatware: 13-0-0
    all outta gum
    Dec 2006
    Poland
    Why would munting the drives that way be hazardous? I can't see a reason for not doing it that way.
    www.teampclab.pl
    MOA 2009 Poland #2, AMD Black Ops 2010, MOA 2011 Poland #1, MOA 2011 EMEA #12
    Test bench: empty
    Jul 2006
    Quote Originally Posted by xoqolatl View Post
    Moving it around i guess would cause a problem if the case isn't handled carefully.
    Honestly, they are there tomporariliy now until i can work out a decent looking front bezel idea, i'll be mounting a 2nd front fan to actively cool hard disks further up the inside front and get them off the bottom.
    ~ Gos
    |Main Rig:
    |Mobo: P6T Deluxe
    |VID: 2x 8800GTX SLI
    |PSU: Neo HE 500w
    |CASE: Antec 902
    OCTeamDenmark Founder Nosfer@tu's Avatar
    May 2004
    Denmark, Copenhagen
    Quote Originally Posted by Goshawk View Post
    ~ Gos
    My first thougth to, But why should they suffer more shock in the bottom than when they where placed the original place ?
    Was it not posible just to remove the middel part of the HDD rack and then mount the 8800 GTX ?
    Former owner of OCTeamDenmark.com
    MSI MOTHERBOARD!!!!!!
    Linkedin
    Jul 2006
    Quote Originally Posted by Nosfer@tu View Post
    It would have been easier that way, but it looks alot cleaner completely removing it. Plus, i can sell the case later by just popping the old rack back in and riveting
    ~ Gos
    |Main Rig:
    |Mobo: P6T Deluxe
    |VID: 2x 8800GTX SLI
    |PSU: Neo HE 500w
    |CASE: Antec 902
    Jun 2007
    The photos are all gone?
  18. #18
    Xtreme Recruit
    Oct 2003
    Upland, CA
    aww yea photos arent working for me either, would be nice to see
    Primary Rig: Intel QX6850 @ 3.3ghz / 2gb Corsair ddr2 1142mhz / 2X 74gb WD Raptors Raid0 / NVIDIA GeForce GTX 280 768MB / Dell 24" / SB X-Fi Fatality / Logitech Z-5500's / Sennheiser HD-595 / Logitech G15 / Logitech Mx518 mouse on Steel Qck
  19. #19
    Mar 2007
    Sydney, Australia
    Photo are not working for me either... I really want to see this
  20. #20
    I am Xtreme
    Apr 2005
    Upstate, NY
    No pix here
    Core i3-550 Clarkdale @ 4.2GHz, 1.36v (Corsair A50 HS/F) LinX Stable
    MSI H55-GD65 Motherboard
    G.Skill 4GBRL DDR3-1600 @ 1755, CL9, 1.55v
    Sapphire Radeon 5750 1GB
    Samsung F4 320GB - WD Green 1TB
    Xigmatek Utgard Case - Corsair VX550
  21. #21
    Apr 2006
    Cape Coral, Florida
    yeah pics are dead try imageshack or something like photobucket
  22. #22
    Jun 2005
    Oregon , USA
    I think he was hosting from his own website.
  23. #23
    Aug 2007
    Guatemala
    i can't see a pic here i want to see , this gtx fit in this little case !
