Page 2 of 2 FirstFirst 12
Results 26 to 36 of 36
Thread: just bought a phase unit. what should i know?
  1. #26
    Oct 2004
    Newcastle Under Lyme - Staffordshire - UK
    Insulate well, keep condensor clean of dust, check fans every now and again, have fun
    O/T - I've never laughed so much whilst sitting in front of a computers. This thread has made my day!!!!
    NoL - Burn wood, take in oxygen from air - mainly carbon in wood becomes CO and CO2 - reduces residual mass of wood. Water in wood evaporates also which reduces residual mass of wood. Mass in = Mass out, system mass is consant.
    "What will become of us, will we evolve"
  2. #27
    Nov 2006
    Quote Originally Posted by SoddemFX View Post
    it was funny alright ..i also lernt some physics ehhe ..is that how ya spell it lol
    Asus COMMANDO -Intel Q6600 @ 3.6Ghz 401x9 have sum test @ 445x9 4GHZ :-)
    2x74 Gig Raptors Raid 0..GSKILL 6400 2x1Mb matchd Pair.-OCZ 550w Powerstream adjustable rails- XE2 Vapochill -pioneer Dvd.-2x160 Gig Hitachi ide drives..-Asus 7600 gs video card
    http://www.hwbot.org/user.do;jsessio...C3?userId=8636
  3. #28
    Mar 2004
    Murfreesboro,TN
    Cool things are addictive... Be carefull
    Lian-Li PC-75B, Asus P5WGD2 WS Pro (BIOS 502), Intel Q6600 G0@ 3.5GHz 1.50V, G.SKILL BHZ, 2048-6400C4,4:3@5-5-5-15-5,EVGA GeForce 8800GTX 768MB, CC-644MHz / MC-1100MHz, HT OMEGA CLARO 7.1, Logitech z-5500 5.1, Enermax 660W SLI, Boot Drive - Raptor X WD1500AHFD 150GB, Two Storage & Backup HD's-WD 320GB SATAII inclosed in ICY Dock Hot swapable HD racks, NEC DVD +/-RW ND-3550A, Lite-on DVD ROM SHOD-16P, 52-in-1 cardreader, Deck Legend-Ice Keyboard, Back to my Logi MX500 @1000Hz
    -monitor#1 Dell 2407WFP rev. A04, res. 1920x1200
    -monitor#2 TV Vizio GV42L, connected with 30' RapidRun cable, Audio - 30' S/PDIF, Belden/Canare cable-> Marantz AV9000 5.1-> 5X 600w ADCOM monoblocks, Veledyne SPL-1200 Sub, SpecResearch keyboard.
    Custom Watercooled->CritiCool PowerPlant PCI Relay Card(modded)->Meanwell S150->Iwaki RD-30-> PA120.3 w/ shroud & Yate Loon D12SL-12 Fans, Nexus fan controller->Storm G5->MCW60
  4. #29
    Dec 2006
    Maryland
    in a chemical reaction, if it were even possible to convert mass -to- energy to a minutely measurable amount of decrease in weight (eg. 0.00001 Kg) the energy yield would be so intense that just by being line of sight of a flame (be it a lighter or a burning leaf) it would be so bright you would go blind, burn you hair off, instant sunburn, ionizing radiation exposure, so on and so on.
    Its simple math
    using Albert Einstein's famous equation E=MC², this proves that a piece of mass smaller then a dust particle can produce enough energy as to make my body move 17 miles. If your not good with math just scroll down to the bottom for the result.
    Formulas:
    “Einstein’s Theory E=MC²” Joules = Kilograms (speed of light)²
    I weigh 150 lbs and I can run about 17Mph tops. so if I run a total of 17 miles (at any speed, but ill say in an hour) I think I will burn ~2015 calories.
    The conversion of calories to joules is:
    1 calorie (4.18) = Joules (variable will be J)
    2015(4.18) = 8422.7
    So if I run 17 miles I produce 8422.7 Joules.
    To find out how much mass I would need to revert to pure energy to produce the same amount of energy it takes for me to run for 17 miles I would need to setup the formula E=MC² as:
    E/C²=M and then fill in the variables.
    8422.7 Joules / (2.99x10^8)² speed of light = M in Kilograms
    8422.7 / 8.9401x10^16 = M
    M = 9.42x10^-14 in Kilograms
    To convert kilograms to pounds:
    1 Kilogram (2.205) = Lbs.
    9.42x10^-14 (2.205) = Lbs.
    Lbs. = 2.08x10^-13
    So if my calculations are correct it should only take
    0.00000000000208 pounds or two trillionths of a pound of mass to produce the same amount of energy I could produce if I ran for 17 miles?
    Think of how much energy you would produce if you burned a piece of wood and lost 0.001 lbs. (0.00045 Kg)
    E=(0.00045)(2.99x10^8)²
    E=(0.00045)(8.9401x10^16)
    E=40230450000000
    You would have produced 40,230,450,000,000 Joules, or 11,175,125 Kilowatt Hours
    I would'nt want to own a fire-place in this case
    Current System Build
    Designaton:" Rad Hat "
    __________________
    • Mother Board, RAM and CPU:
      Mobo: Asus Maximus Formula (SE) BIOS 1207 | CPU: Intel q9650 @ 3.80GHz Vcore 1.272v | RAM: Crucial Ballistix Tracer PC2 8500 4x1GB
    • Graphics Processor:
      GPU: BFG 8800GTX | BFG 8600GT (Quad Monitor Setup)
    • Hard Drives:
      RAID: 2x 74GB Raptors on RAID 0 for OS Drives
    • Case and Power Supply:
      Case: Antec Case | PS: OCZ ProXstreame 1000W
    • Water Cooling:
      Pump: Swiftech MCP655-B | Rad: Dual Swiftech MCR320's | Fans: 6x Yate Loon D12SH-12's (W/ Variable RPM Rheostat) @ 88CFM Max Each - 528CFM Total!!!
    • (Water Blocks and Fittings):
      CPU: D-Tek Fusion Block | GPU: Danger Den Full Coverage 8800 Block | Mobo: EK's Mosfet, NorthBridge and SouthBridge Blocks
      Res: Swiftech Micro | Tee's: 4x MartinM's High Flow Copper Tee's | Elbow's: None | Y's: None
    Flow Order: >> Rad's 1 & 2 in parallel > Res > Pump > CPU > GPU > SB > NB > Mosfet 1 > Mosfet 2 >>
    Temperatures: CPU: 57°C Max, Running Prime95 | GPU: 58.3°C Max, Running 3Dmark | NorthBridge: Untested!
    Last Updated 11/11/09
  5. #30
    Oct 2004
    Quote Originally Posted by n00b 0f l337 View Post
    Phase first, condensation is water, mass cannot be created nor destroyed just transmuted. So, unless you can turn water to gold (in which case pm me ), it'll stick around as either water or ice or water vapor. So you need to insulate so it never forms.
    I've seen some of Sneils work, its good, shouldnt have any suprises.
    See what you've started NoL???!!!!!
    Tom
  6. #31
    Xtreme Mentor
    Mar 2006
    Redvers, Sask, Canada.
    From phase change to nuclear physics and chemistry, lol if you're going to go off topic go off topic good!
    Bring back natural selection! No more warning lables!
    The one and Only MG Pony
  7. #32
    Dec 2006
    Maryland
    thats how we roll
    __________________
    • Hard Drives:
    • Water Cooling:
  8. #33
    Oct 2006
    England
    Do i hear Quantum Physics anyone, whats next?
  9. #34
    Xtreme Mentor
    Mar 2006
    Sneil brought in Quantume physics, I need more caffine if I'm going to play in that thread though!
  10. #35
    I am Xtreme
    Mar 2005
    But why can't I get you guys to start simpler, buy or go to your library and read a good Reference Book on refrigeration.
    The Laws of Thermodynamics say:
    Zeroth Law: "You must play the game."
    First Law: "You can't win."
    Second Law: "You can't break even."
    Third Law: "You can't quit the game."
    Do you wanna Play Thermodynamics ???????? I forgot "you must"
  11. #36
    Apr 2005
    Closer than you think.
    Quote Originally Posted by wdrzal View Post
    Exactly.
    If you guys want to flex your brains OT in someones thread, there's a different section for it.
    Besides the fact that someone asked a reasonable question and got quantum mechanics thrown at him, it doesn't have anything directly to do with refrigeration in any way that matters.
    Thread closed.
    Gray
    [SIGPIC][/SIGPIC]
