+ Reply to Thread
Results 1 to 16 of 16
Thread: x1650pro and Ghost Recon Advanced Warfighter
    Oct 2003
    Montreal Canada
    0
    well me and my friend tryed to play ghost recon, he has a 7900 so hes fine. My rig was:
    P4 3.0E prescott
    Abit ic7-max3
    Kignston hyper X pc3500 2*256 dual channel
    ATI 9800pro
    I had like 10 fps , the game on all high settings looked like a 1998 videogame, no details no texture... awful.. and my crossair was aiming so bad it was always moving around i couldnt aim at all.
    so i decided maybe its my videocard ill just go get a x1650pro 512mb DDR AGP8x it will probably get 30 fps i hope, its a videocard 2 generation after the 9800pro
    so i got it and its 30days full refund so i dont mind getting a card.
    i installed and now what, its the exact same thing. the game looks like a 1998 videogame, lags the same, same crossair problem....
    i tried my other video games... Warcraft 3, prince of persia3, guild wars... i see no improvement in ALL of them , same fps in all of the games, even prince of persia seems to have lower fps. ( i usually use 1600x1200, 16AF and no AA with all graphics on high in all of the games)
    so basically is the x1650pro that ty or i just installed it bad or my cumputer really do suck... anyway thanks to all
    Current rig:
    Intel E6750 @ 3.6
    Gigabyte P965-DS3
    Crucial Ballistix Tracer DDR2-800 2*1GB @ 449mhz 4-4-4-12
    eVGA 8800GTS 320MB @ 625/1000
    2*Raptor 36.7g 10k rpm
    All STOCK HSF air cooled
    Old school rig ^^:
    Intel Pentium 4 3.0e @ 4.01
    Abit IC7-Max3
    KHX 3500 2*256 Dual Channel
    ATI 9800pro @ 9800xt
    CPU+VC Watercooled
    I am Xtreme tiro_uspsss's Avatar
    Jan 2006
    bouncing between Perth & Sydney
    40
    ur lucky it ran on ur 9800pro! my frind has same card, & it wont even run!... not sure y urs isnt running at least a lil smoother - ur cpu is ok, so is the card.. ur ram is a lil low though.. try latest ati drivers..
    DNA = Design Not Accident
    DNA = Darwin Not Accurate
    the yummy FOOD
    thread
    heatware / ebay
    Live Long And Overclock perkam's Avatar
    Sep 2004
    0
    Please read this carefully
    A. Can you still return it?
    B. WHere do you buy from? (website)
    C. Whats your budget?
    Perkam
    Oct 2003
    Montreal Canada
    0
    Quote Originally Posted by perkam View Post
    Perkam
    A. Yeah i bought it at futureshop.. cause i know its 30 days full refund
    B. Futureshop....
    C. I just want to buy a card to play that game for like 2 weeks with my friend then refund it lol... i dont plan on keeping it because all my favorite games run good on my 9800pro...
    Current rig:
    Intel E6750 @ 3.6
    Gigabyte P965-DS3
    Old school rig ^^:
    Abit IC7-Max3
    CPU+VC Watercooled
    Sep 2004
    0
    Quote Originally Posted by NesQuiK View Post
    B. Futureshop....
    oh ok...well truth be told the 9800 pro was on par with the x700pro, which is on par with the x1650pro...hence the performance you got.
    However, we'll have to reconsider your membership at xs if you buy video cards from Futureshop X(
    Perkam
    Oct 2003
    Montreal Canada
    0
    lol the only reason i bought it at futureshop is because i know they give total refund i know that im not keeping the card...
    Current rig:
    Intel E6750 @ 3.6
    Gigabyte P965-DS3
    Old school rig ^^:
    Abit IC7-Max3
    CPU+VC Watercooled
    Banned
    Jun 2006
    Durham, NC
    0
    Have you ever considered maybe more RAM would help? I mean, 512MB is nothing for modern games. You should consider at least a gig, or even 2GB as average 2GB kits are dirt cheap now.
    If you're seeing terrible lag across the board it points to a problem other than the video card, save the rare instance that you got a defective unit.
    And Perkam, the X1650PRO is meant to perform in the same ballpark as the 7600GT, so I'm not seeing the comparison you're drawing between it and a 9800Pro, which doesn't even feature SM3. Hell, the 9800Pro is almost 4 years old, man.
    Oct 2003
    Montreal Canada
    0
    that would explain the lag, but what would explain the low detailed textures and terrains... and graphics , its really ugly even everything on high
    Current rig:
    Intel E6750 @ 3.6
    Gigabyte P965-DS3
    Old school rig ^^:
    Abit IC7-Max3
    CPU+VC Watercooled
    Banned
    Jun 2006
    Durham, NC
    0
    If you are able to borrow someone's RAM, like 2x512MB or better yet, 2x1GB, I would suggest running tests under that configuration. If you still see graphical anomalies and artifacts, it's likely bad vRAM or something similar. However, it may just be that you're pushing the card beyond its limits. Gaming at 1600x1200 on an X1650Pro is pushing it, especially with details on high.
    Oct 2003
    Montreal Canada
    0
    for ghost recon i am not using those settings, im using like eveyrithing on mimum at 800x600 and it has like 10 fps .... i tryed though at 1280 everything at max... still really ugly i dont even really see a difference, but at my friend's though with is 7900 its so nice and smooth. what i mean is that with the same settings of graphics... without taking notice of the lag , its wayyyyyyyyyyy nicer on my friends 7900 than on the x1650, even if i set every settings to the same.
    Current rig:
    Intel E6750 @ 3.6
    Gigabyte P965-DS3
    Old school rig ^^:
    Abit IC7-Max3
    CPU+VC Watercooled
    Sep 2004
    0
    Quote Originally Posted by Omastar View Post
    And Perkam, the X1650PRO is meant to perform in the same ballpark as the 7600GT man.
    Eh?
    The X1650Pro is originally a rebadged X1600xt, which sucked arse against the 7600GT...hence the reason the X1650XT had to be released to be on par with the 7600.
    Check the numbers before thinking you know more than someone who waited 3 years for a decent mid range offering after the X800GT.
    Perkam
    Banned
    Jun 2006
    Durham, NC
    0
    Eh?
    Perkam
    Maybe I'm thinking of the X1650XT?
    Sep 2004
    0
    Most likely....which this isn't...its a half as*sed 4 pipeline card...much slower even than the x700pro or the x800gt.
    For the same price you could have bought a nice agp 7600GS...which should've ran GRAW a tad bit better.
    But yea...if you wish to see 30 fps, even at 1024x768, you'll need an x1950PRO/X1900GT/7900GS.
    Perkam
    Xtreme 3DTeam Member
    Jan 2004
    Cascadia
    0
    Perkam
    How dare he challenge your veritable fountain of knowledge!?!?! The nerve!
    Omastar, just wait 4 years for your next card and you can know even more.
    In all seriousness, X1600XT overclocked and Xfire'd can provide good(realtively, of course) frame rates. I'm not saying you couldn't buy a better card for the price of 2 X1600XTs though.
    Official ORB bottom feeder.
    Sep 2004
    0
    Two times the Crap doesn't = Good.
    X1600XT in most games, even in xfire, would drop to single card performance levels even at 1024x768 when as little as 4xaa and 8xaf was enabled.
    The exceptions that are there like CoH and a few others that have recently seen better performance from these cards is due to drivers, which sucked for many months after launch.
    Perkam
    Jan 2004
    Cascadia
    0
    Perkam
    It all depends on what you play and how (what res. and settings). That is why I qualified my statement with the word, relatively. Even though I fat fingered a key and spelled it wrong.
    For me, the cards work just fine. Of course I'm not a serious gamer, either. I speak from experience in over a year of running X1600XTs, crossfired, at over 800Mhz core.
+ Reply to Thread
