Looking to upgrade my system soon and will want the best radiator I can fit into a high end case like the TJ07.
I have a number of options. The well known PA120.3. Or the GTX480 (shown below). The PA120.3 is 10mm thicker than the slightly longer GTX480 but both fit into the case without any problems.
I'm neutral about brand names. And I'm aware this may be viewed as an unfair comparison (i.e. there is no PA120.4). However, I just want to know the "best" internal watercooling radiator that fits into a modern high end case. Does anyone have any test results showing which is #1? Alternatively, any views on why one is better than the other?
