Hi all.
I thought I would update my Nvidia drivers as I have some problems with TOCA3 and newer drivers are supposed to help.
I downloaded the 165.01 drivers but laptop GPU's are not supported.
In the past I have downloaded a modded inf from laptopvideo2go but there forum is down as a HDD died
I tried modding the inf myself adding these lines -
%NVIDIA_G72.DEV_01D7.1% = nv_NV3x, PCI\VEN_10DE&DEV_01D7
and
NVIDIA_G72.DEV_01D7.1 = "NVIDIA GeForce Go 7300"
With these lines added I could install the driver and it seemed to work ok, appart from damned TOCA3 crashes to desktop when I load it.
I got a big performance gain from these drivers in other games, they just wont work with TOCA3. TOCA does work when I roll back the driver.
Problem is that im I dont really know what im doing modding these INF files so is there anything else I should do to get them compatible with the 7300go ?
People on laptopvideo2go had them working with the 7300go but I cant get there Inf file untill there forum is back up.
Plus I would like to learn a bit mroe about how the drivers work anyway.
Im using vista 32bit
Any ideas, all help greatly appreciated.
