Now that I think about it mine didn't even come with directions!
EVGA 680i
X6800 @ 3.8ghz on water
2gb Corsair Dominator 1250
EVGA 8800GTX w/ EK water block
Got mine from the UK. Perhaps they weren't even the DD instructions but the vendor's. Who knows - anyway as long as it works, it's all good. Think that's all I got to say...![]()
- PC1: Q6600, Gigabyte P35-DQ6, Corsair HX620 PSU, 8800GTX, 4GB RAM, TJ07 case, 2xSamsung F1 750GB w/Scythe HD enclosure, Thermochill PA120.3 + PA120.2, Laing D5 Vario, D-Tek FuZion, EK FC8800GTX, T-Balancer bigNG, 5xNexus D12SL-12 fans @ 500 to 950rpm
- PC2: i7 920, Gigabyte GA-EX58-UD5, Modu82+ 625 PSU, GTX 260 (216), 6GB DDR3, 2xSamsung F1 1TB, LG GGC-H20L HD-DVD & Blu-ray, HR-01 Plus & Fan Duct
Mine didn't either. Had to invade another person's computer, drag my mobo tray in and do the installation in front of them. I've been quite unhappy with DD's fall from grace. They need to get their act together. Luckily, a specific e-retailer was kind enough to send me replacement parts for the missing stuff at their cost.
Been out for awhile. Just caught up with this thread....It would seem that we got different sheets with our "680i Maze 4" blocks.
Here's what I got;
This shows my confusion as to the jam nuts, and probably half the other folks as well. These instructions imply that the 4-40 posts need jam nuts on the top side of the board. I got four, 4-40 threaded rods. Not two as pictured, so I thought this kit was ready for the 680i. I know printed directions can lag a manufacture, so I went with the directions provided, looked at the DD website for updates, and found none.
As Echn111 says, why would I place a jam on the top of the board since there are obvious traces there? I asked the same thing. Aurora apparently got a newer kit, since he saw the same issue, but from a different context, since he didn't even get the misleading directions I got.
Bottom line is this, don't stick the jam nut on top without a nylon washer, or you'll let the smoke out of your board.![]()
To Ranker, we are talking about cutting a "nylon shoulder washer", as in the pic above to clear the chip in question. 20-20 hindsight, I would do as Echn111 did and skip the top jam nuts altogether. But, since my machine is not currently burning, I can say the modded shoulder washer works too. I cut mine such that the jam nut does not press on the chip below.
My other suggestion to DD is to provide 4-40 screws and not posts. Posts usually use the jam nuts to secure the post from coming loose. If they had provided screws, we likely wouldn't be having this thread.
Regards,
Bob
Bob,
You'd still need 4 nylon washers to go between the screw heads and the bottom of the board. The only way they can get away with 4 nylon washers is in the scenario on the sheet you scanned, which is what was included with my DD 680i block. They added the extra posts, nuts, springs, and sleeves, but completely forgot the extra nylon washers required for a 4 post install. I figured I was just shortchanged those 4 washers in an isolated incident, but it seems like most of us are missing the same parts. This leads me to believe that DD doesn't even realize that they're making the mistake. But then again, I did buy the block from Jab-tech, so maybe they're the ones taking the washers out of the 680i kits in order to conspire against Danger Den! :P
Main Rig:
Q6600 G0 @3.7ghz 1.425V - EVGA 680i A1 (Vdroop mod) - 4GB G.Skill HZ DDR2-800 @1000mhz - EVGA 8800 Ultra SLI @710/2460mhz - 2x WD Raptor X 150GB RAID 0 - 2x WD 500GB RAID 1 - 1x WD 320GB eSATA External - SB X-Fi XtremeMusic - Enermax Galaxy DXX 1000W - NEC 16X DVD±RW DL - 2x Dell 2405FPW (Dual monitor w/ SLI!) - ATI Radeon X300 - MM U2-UFO Horizon
Dual loops:
D-Tek FuZion (Bowed) - PA120.3 - Dual DDC2+ w/ PT tops - Swiftech MicroRes - Distilled w/ Red UV dye
2x EK FC8800 - DD680i NB - PA120.2 - Dual DDC2+ w/ PT tops - Swiftech MicroRes - G11 UV
Temps: 28-29degC idle / 46-48degC load with MX-2! Pics of my build!
Dedicated Cruncher:
Lapped E6600 @3.6ghz - MSI P35 Platinum - 2GB Crucial Ballistix DDR2-800 @933mhz - MSI 8500GT - 320GB WD - Lapped Big Typhoon - Seasonic M12 700W
Yup RX7, I totally agree. I'll shoot DD an email pointing to this thread. (I'm a "local" for them.) You're probably right that they may not even know of the issue. The chip clearance issue is also important for them to know.....
Regards,
Bob
Just got one of these and I've been shorted 4 washers too. I'm not convinced the solution is to not run the jam nuts on top as then when you adjust the brass knurl up top, theres nothing to stop the rod from unscrewing at the bottom.
Not impressed with the quality - there are scratch marks on my lucite from when a tool has slipped attaching it to the block.
