just got mine non-extreme by this morning
running 400x9 @ 1.5v
im loving it
350x9 @ vcore stock
environment temperature: 15°c
idle: 17°c
burning: 45°c
400x9 @ 1.5
idle: 20°c
burning: 51°c
now im gonna try some superpi and other stuffs
cheers
GA965P DS3 / E4300 @ 3.6ghz / Thermalright Ultra 120 + Vantec 120mm / 1gb ddr667 / 7600GT
For those that are stilling looking for this HS, its in stock at a few places.
Petras( recommended)
Newegg
Not my link, found it though froogle, but one is on ebay? Not sure if i am allowed to post the link? If not i apoligize. Just trying to help fellow clockers out
Heatsink factory was in stock, but now out of stock.
So these 2 places are the only ones that i know of that have them. Wont last long.
Seems like supplies are getting a bit better all around.
CPU: Q6600 @ 3.6ghz G0 Week 37B
Mobo: Asus P5k Deluxe
Cooler: TRUE 120 (150cfm Delta)
2xHR-05
2xHR-09
Mem: G.Skill 4x1Gb 6400HZ
Vid: HIS 4850
HDD: 80Gb 16mb Cache Raptor
500Gb 7200.11 Seagate
PSU: Enermax Noisetaker 600w
Case: Thermaltake Armor (4x120mm 104CFM Panaflo)
3dmark06: 16k
HEHEHHEHE
My stuff arrived!!!!
2xHR-05
2xHR-09
Vid: HIS 4850
3dmark06: 16k
why 2 ?
ASUS P5K-E // E8400 Q746A519
G.Skill F2-8000CL5D-4GBPQ
LC 550W GP// XPERTVISION 9600GT
Hi, I just had a thought with my Ultra 120 Extreme. Currently, I had planned on mounting a Yate Loon D12SM to it but why not mount another fan, specifically an S-Flex(I was going to get it originally but didn't want to spend so much money but now this idea came into place)? The only way I can think of mounting it an easy way is using a rubber band. Seemed pretty stable but I just would like comments if this idea is insane or not.
OT: btw, is any there a sort of newb guide on how to remove the 4 pin connectors on all my yate loon case fans? They are creating a pretty bad mess already. I don't exactly have the tools for it either, IF there are specific tools for it.
Not insane at all. I run 2 fans on all my Ultra-120s, in a push-pull config.
It drops load temps by about 2 degrees. Hardly the second coming, but what I like about it is that if your primary fan should fail you won't have a meltdown crash.
I also prefer 2 quiet fans that give me the same effect as a howling medium or high speed Panaflo for way less noise.
Intel Core 2 Duo 6400 & 6600's
6400: 2.1GHz overclocked to 3.360 Ghz, 1.450V Vcore, Asus P5W-DH Deluxe, Rev 67MOAG BIOS 1305 -TTBT
6600: 2.4GHz overclocked to 3.600 Ghz, 1.5375V Vcore, 3.708 Ghz, 1.5750V Vcore, Asus P5W-DH Deluxe, Rev 68MOAG BIOS 1602 - Ultra-120
QuadCore Q6600: 2.4GHz oc to 3.456 Ghz, 1.5625V Vcore, Asus P5B-Deluxe Wifi, Rev 1.03G BIOS 804 - Ultra-120 Extreme New Build, still testing.
Gskill F2-6400PHU2-2GBHZ (4 x 1GB)
Antec Truepower2 550w EPS
Ok. And the removal of the 4 pins?
2xHR-05
2xHR-09
Vid: HIS 4850
3dmark06: 16k
just found it in Canada for dirt cheap.
http://www.ncixus.com/products/23531.../THERMALRIGHT/
dfi 680 & 965,6700's, 8800gtx, x1900xtx, ga 45-ud3p, 8400, x3440 tp55,9800gtx+
II X2 555 & ta790gx?
funny thing is that ncix canada has it for a lot more.
2xHR-05
2xHR-09
Vid: HIS 4850
3dmark06: 16k
