Anandtech's Review of the Ultra 120 Extreme.
http://www.anandtech.com/casecooling...oc.aspx?i=2943
Anandtech still rates the Tuniq 120 as the reigning champ of the aircooling world. Have they never used an enzo?
Not really....
Don't confuse their comments on the vanilla 120 with the 120E.However, the best air cooler we have tested is the Thermalright Ultra 120 Extreme. It cools better at all speeds and overclocks, and overclocks the processor further than any air CPU cooler we have tested.
[SIGPIC][/SIGPIC]
Lian Li V2000+ Modded
Intel Core I7 920 @ 3.8Ghz 1.325v Thermaltright Ultra 120 Extreme RT1366
Asus Rampage Extreme 2
OCZ 3x2GB DDR3 1600 Platinum
EVGA GTX460 768MB 850/1700/2100Mhz SLi
EVGA 8800GT SSC 730/1800/2000Mhz
Corsair HX850W
that review is older, perhaps TR changes this in the final moments of it shipping.
Silverstone Temjin TJ-09BW w/ Silverstone DA750
Asus P8P67
2600K w/ Thermalright Venomous X Black w/ Sanyo Denki San Ace 109R1212H1011
8GB G.Skill DDR-1600 7-8-7-24
Gigabyte GTX 460 1G
Modded Creative X-Fi Fatal1ty w/ Klipsch Promedia 2.1
1 X 120GB OCZ Vertex
1 X 300GB WD Velociraptor HLFS
1 X Hitachi 7K1000 1TB
Pioneer DVR-216L DVD-RW
Windows 7 Ultimate 64
That would be totally retarded... there are way too many 939 socket users out there and me being one of them.. they're going to exclude them for a 1$ bracket.. WTF....??!!
I held off my 120 purchase for the Extreme version but now it looks like they give me the finger... well I'll return the favor then....
Corsair HX850W
that bracket is probably $1 at most COST. To buy it separately I bet it is more like $6+.
I too am using a Big Typhoon and wouldn't mind changing it for this as I know I could always reuse the cooler if I were to go with something else down the road.
I know this works for AM2 and C2D but would it work on the new AMD Barcelonas that are shipping this fall? I ask because I have looked too into its socket size/type etc. For the price and a little time changing it, it might be worth the effort. Every time I say I'm done with my computer something else comes up I want. This, plus the new 1TB Hitachi HD and of course the HD X2900. Sigh. I am suppose to be saving for a new car too.
Asus P8P67
Gigabyte GTX 460 1G
That's what I meant... it can't cost them more then $1 to produce the damn bracket.... hell it's probably the same bracket as used for the regular Ultra so it's probably even cheaper....
Hardware sucks..... if you want to stay on top of the game that is.....
Corsair HX850W
I wish someone would compare the coolers with a Kentsfield @ 1.5+ Vcore. That's what'll separate the men from the boys.
DDTUNG
XtremeSystems - we overclock and crunch you to the ground
I left the optimized files on three 3GHz P4 HTs. Ban me.
Kentsfield Q6600@ 3100Mhz
Asus P5B-E Plus
2GB GSkill DDRII PC6400GBHZ
Albatron Geforce 8800GTX
Corsair 620W HX
74GB Raptor/ X-Fi Platinum
19" CRT NEC 930 SB
Windows XP Pro SP2
Anyone have any news about stocks in UK? I need to replace this XP90 asap
i5-750 w/ Thermalright Ultra120X
Coolermaster HAF-932
MSI GD65
2x2GB G.skill Cas7 1600MHz
Sapphire HD6870
Western Digital 640GB.AAKS
2x Samsung F1 1TB
2x Samsung SLC 64GB SSD
Pioneer DVR-212BK
Corsair HX620W
Creative X-Fi Xtreme Music (dead, using onboard -.-)
LG W2286L
All of you who are dissing on the BT , you should lap the hsf and lap your IHS and then see what kind of a cooler it really is. Thermaltake takes away from its efficiency by giving it a really crappy base and most IHS are not flat. It was good enough to keep my opteron 146 at 1.6V below 45C load after I lapped it and I popped the IHS off the opteron. And thats with the stock fan. Its a very good hsf for its price ,it just needs some effort on your part.
regardless TR 120 Extreme loooks like a really good hsf , however I HATE the nickel plated bottom that TR loves to give its hsf. We know its copper at the bottom , so why mess with the nickel and hinder its performance. I lapped my XP120 and it keeps by Dual Core 3600+ at 3ghz below 60C with a panaflo at 7V.
regarding the BT, mine was pretty flat and didnt need any lapping, but i can't imagine anyone needing to lap it since its tightened by nuts. if one side isnt as flat as the other, would'nt u just tighten the nuts on that side an intsy bit more? its not like this is a clip on heatsink w/ pushpins here.
Opteron 165 @ 312x9-->2808mhz w/ TT big typhoon, DFI LP Ultra D, 2x1GB OCZ Platinum 3200EL @ 2-3-3-10, X1900XT 512mb, 250gb hitachi T7K250, audigy 2, enermax 460wt psu w/ 33a 12v, antec p160, winxp pro
I wonder when aircoolers will start bowing the bases....with high clamping pressure mounts, it'd really help a lot.
My bt is lapped 2 a perfect mirror finish and has a 150CFM delta on it...
After this it still is mediocre
not 2 mention I use liquid pro TIM too.
CPU: Q6600 @ 3.6ghz G0 Week 37B
Mobo: Asus P5k Deluxe
Cooler: TRUE 120 (150cfm Delta)
2xHR-05
2xHR-09
Mem: G.Skill 4x1Gb 6400HZ
Vid: HIS 4850
HDD: 80Gb 16mb Cache Raptor
500Gb 7200.11 Seagate
PSU: Enermax Noisetaker 600w
Case: Thermaltake Armor (4x120mm 104CFM Panaflo)
3dmark06: 16k
Anyone suggest some good fans to strap to one of these?
Core 2 Duo E6600 2.4ghz
eVGA 680i Rev. A1
2x1gb Crucial Ballistix DDR2-1066 PC2-8500
eVGA 8800GTX
Seagate Barracuda 320gb
WD Caviar 320gb
FSP Epsilon 700w
Just something that'll give me good temperatures without slipping into the Delta noise range.
eVGA 680i Rev. A1
eVGA 8800GTX
WD Caviar 320gb
FSP Epsilon 700w
Go for the fan anandtech uses, Scythe S-Flex (medium one I believe, not sure though).
Anandtech used the high end model, the F variant. SF122F I believe the model is. 64cfm at 28dba, it really is to be quite quiet. I am looking to getting a couple of these for my case.
I don't know why but I have always preferred panaflo fans for my cpus.
Asus P8P67
Gigabyte GTX 460 1G
On a slight off-topic note, what would be a good cooler for the northbridge on 680i, which wouldn't smack into the 120?
eVGA 680i Rev. A1
eVGA 8800GTX
WD Caviar 320gb
FSP Epsilon 700w
Aha, so it was the higher model. You're right, I had to look up the one I bought, the -E model, and that thing is pretty damn quiet. I'm sure the -F will be a tiny uptick in noise, I'm personally going to use the -E model on my Ultra-120e
Jab-tech now has it on their site, just ordered it, a Scythe -E fan, two yates for case fans.
Looks like it will fit in the review i read the used the EVGA 680i
http://www.anandtech.com/casecooling...spx?i=2943&p=2
