Results 1 to 6 of 6
Thread: 8800 GTS SLi Vs. 8800 GTX
    Feb 2006
    as the title says.. which will be better?
    are there any online tests like this?
    Rig:
    Q6600
    Intel BadAxe2
    Tuniq 120 Tower
    G.Skill HZ 4x1GB
    BFG 7900 GS OC (558/675) now MSI HD 7770
    WD Raptor 150GB (Primary)
    2 x Seagate 320Gb 7200.10 (Storage; No RAID)
    Corsair 620Watt
    Samsung SH-W183 SATA drive
    AuzenTech X-Meridian
    Antec A900 Case
    I have a Tuniq 120 Tower in my new pc. The size, in relation to others on the market, is directly proportional to the size of my penis. Therefore it is large.
    and thick.
    Apr 2006
    Russia
    Sorry for my bad English
    Xtreme Cruncher
    Dec 2006
    Palo Alto, CA
    8800gts sli should be better...
    Lenovo Thinkpad X220 - Core i5 2410m, 4gb
    waiting on 28nm video cards...
    Egyptian OverClocker
    Mar 2005
    Cairo, Egypt
    IMHO it depends on ur system and games config
    cause if u r using a 19 or 20" widescreen for example the single 8800GTX will be good enough and will also reduce the consumed power and dumped heat in ur system
    while 2 GTS will be handy imho if u play using high resolution
    Soon to be :
    ASUS P8P67 Deluxe, Intel SB i7-2600k, G.Skill Rj-X F3-12800CL6D-4GBXH, MSI HD6950 2GB, Corsair 750AX, Intel 80GB G2 SSD, DELL U2410
    Used to be: SaFrOuT
    Jan 2007
    The usuable memory in SLI is the same (available memory does not stack double) as with a single card; SLI will not "Add" or expand the resolution to a monitor setup! I learned this from others. 512 + 512 in SLI = 512
    Rig #1:___Silverstone TJ09, GA-EP45-UD3R, Q9550, 4GB G.Skill, XFX HD 5870, Thermaltake 850W, Vista X64, ASUS 1920x1200 VW266H Black 25.5" 2ms(GTG) 1920x1200
    Rig #2:___Lian-Li PC-7 Plus II, P5K DLX (bios 1005), Q8400, 4 GB Crucial Ballistix, 8800GTS [640mb/G80], CORSAIR 620HX, Vista X64, Samsung SyncMaster 226BW 1680x1050
    Acer notebook & netbook, iPhone, & Touch, etc.
    Mar 2006
    I believe that if you are interested in 3DMark scores, you should get the 2 GTS's. If not, get the GTX, you won't have any problem in today's games and you can always get a second
    Lian Li V2000A+ Silver | Abit IP35Pro | Core 2 Quad Q6600 G0@3.2GHz@1.35V | Sunbeam Tower 120 | Sapphire HD 3870 X2 @ default | 4x1GB Crucial Value 800 D9GKX @ 800 | OCZ XTC RAM Cooling | Silverstone Olympia OP750W | 2x150GB Western Digital Raptor-X@ RAID-0 (30GB + 270GB) / 3xLacie (Seagate 7200.10) 500GB USB 2.0 | NEC 3520A + Samsung SH-S183A S-ATA | Auzentech X-Fi Prelude | ΕΙΖΟ S2431W | AKG K701
