Basic ACDSee window. That slider has a big impact on quality obviously, but what is the best setting for all the options?
My watercooling experience
Water
Scythe Gentle Typhoons 120mm 1850RPM
Thermochill PA120.3 Radiator
Enzotech Sapphire Rev.A CPU Block
Laing DDC 3.2
XSPC Dual Pump Reservoir
Primochill Pro LRT Red 1/2"
Bitspower fittings + water temp sensor
Rig
E8400 | 4GB HyperX PC8500 | Corsair HX620W | ATI HD4870 512MB
I see what I see, and you see what you see. I can't make you see what I see, but I can tell you what I see is not what you see. Truth is, we see what we want to see, and what we want to see is what those around us see. And what we don't see is... well, conspiracies.
I'm glad this came up.
I work in Photoshop and usually save with a quality of 10 and "Progressive" as any higher greatly increases file size and does not offer any difference unless you studied them up close, flipping them back to back.
That is what I have found works best for me. I'd like to know what the "ideal" is.
System
ASUS Z170-Pro
Skylake i7-6700K @ 4600 Mhz
MSI GTX 1070 Armor OC
32 GB G.Skill Ripjaws V
Samsung 850 EVO (2)
EVGA SuperNOVA 650 G2
Corsair Hydro H90
NZXT S340
For online publishing, I use "73" via Photoshop's "save for web" (no preview thumbnail [smaller size], higher control of final saved image w/o changing the original). It has EXACT filesize estimation....also has full GIF and PNG control
For sharing with family or for archiving, I keep it at around 90.
The first is equivalent to a "9" in Photoshop's 1-12 scale, the latter I use "11."
"Progressive" is for online purposes....essentially allows the image to be rendered progressively if it's slowly loaded. This is for dialup connections mainly....only changes the data pattern (though is typically a larger file).
I have compared the file size difference in Progressive and it is trivial.
Using "Save for Web" kills all the EXIF data, so that isn't an option for a lot of people like me.
System
ASUS Z170-Pro
Samsung 850 EVO (2)
Corsair Hydro H90
NZXT S340
I am learning.
So why would I care about EXIF data?
Water
Laing DDC 3.2
Rig
http://www.digicamhelp.com/learn/glossary/exif.php
http://www.digital-photo-secrets.com.../what-is-exif/
You can view EXIF data for a photo in Photoshop, or in the Opera browser by right clicking a picture. Its very useful.
System
ASUS Z170-Pro
Samsung 850 EVO (2)
Corsair Hydro H90
NZXT S340
actually what I prefer is to use the preview option and reduce the settings until the point where it doesn't look like I want it to
Fast computers breed slow, lazy programmers
The price of reliability is the pursuit of the utmost simplicity. It is a price which the very rich find most hard to pay.
http://www.lighterra.com/papers/modernmicroprocessors/
Modern Ram, makes an old overclocker miss BH-5 and the fun it was
Ditto....but for more reasons than just JPEG compression (as I'm sure you do).This I actually don't do. I only save exactly what I plan to publish as I plan to publish it and in a separate folder. I keep the RAWs and the accompanying .xmp files and just reprocess the photo if I ever need to reuse it later and the existing file won't work.Originally Posted by Magnj
Regarding EXIF....never found a use for it so I just ditch it Just takes up extra bits for me....my file system already has dates built in and the camera settings are of no import to me (I only occasionally care about ISO, but I can tell which setting I used just by looking at the image [for my cameras]).
Right. I save the original DNG files in a dated folder, make a sub folder for modified photo's and save anything I plan to publish in there. Sometimes I end up with 2 copies of a file in the sub folder because of my work flow though.
I usually use quality at 93% and disable the 2:1 option for maximum quality
as my new avatar of my cat taken a few days ago shows
I generally use 10 baseline optimized in photoshop, it seems to give good results.
Also you can get an exif viewer plugin for firefox here.
CPU Temps: Forget MBM, if it don't crash it ain't too hot.
