Results 1 to 13 of 13
Thread: When do you need a macro lens?
    Xtreme X.I.P. Soulburner's Avatar
    Oct 2003
    Lincoln, NE
    And is a macro lens different than a close-up lens?
    How is it different than a teleconverter?
    Basically I want sharp, focused close-ups of objects at distances like you would find at a zoo (animals). Would I need one or is my S3 adequate out of the box?
    System
    ASUS Z170-Pro
    Skylake i7-6700K @ 4600 Mhz
    MSI GTX 1070 Armor OC
    32 GB G.Skill Ripjaws V
    Samsung 850 EVO (2)
    EVGA SuperNOVA 650 G2
    Corsair Hydro H90
    NZXT S340
    Jan 2005
    NJ
    Macro Lenses are for pictures at or greater than 1:1. This means you want a photo of a penny at really high detail. This would be taken with a 50 or 100mm lens. What your talking about it simply a zoom lens. If you want sharp pics of something far away that is simply a zoom lens in the 100+mm category.
    As far as your S3 goes I have no idea on the focal length of that lens
    CPU Z:2700 2k1:27952 2k3:12282 2k5:5763 PCM05 AQ3
    Opteron 165 s939_____OCZ RAM/PSU_____BBATI X800xl
    Oct 2003
    Lincoln, NE
    I found out that all a macro lens does is let you get physically closer to an object and still focus.
    I don't need one for my S3 then. I can focus on an object all the way down to less than 1cm from the lens.
    So that doesn't really make sense to me. All of my cameras have done fine at focusing on objects up close, I thought that was normal and focusing on objects very far away was the problem.
    System
    ASUS Z170-Pro
    Samsung 850 EVO (2)
    Corsair Hydro H90
    NZXT S340
    Mar 2005
    houston TX USA
    yeah, macro lense will let you get like.... camera--> | |<-- object
    and still have clarity
    most digital cameras will have a "macro" mode button, or a "super macro" mode, which lets you get 3 inches with detail, or 1 inch or less, with detail respectivley on my camera.
    emptiness
    Dec 2005
    Brooklyn, New York
    Quote Originally Posted by Soulburner View Post
    If your S3 is hunting at the long end of the zoom, just use center point or you can move the point around manually iirc.
    Heatware: 50-0-0
    Quote Originally Posted by Charile
    I believe that GWB, who may NOT be the best overclocking CPU in the tray...
    Quote Originally Posted by -thc-(cZ) View Post
    oh c'mon, maxxx, kick that cat of that monitor and have it poop for you
    Royal Administrator
    Jul 2005
    New York City
    Super Marco mode seems work, but I'll buy a Canon 500D 58mm Close up Lens since I have a lens adapter/hood tube for S3 IS.
    Xtreme X.I.P.
    Dec 2005
    this is when you need a macro lens
    A macro lens does 1 of 2 things-
    1) it is typically sharper than your standard lens, since you need really sharp images when you are taking close ups. Sharper means better quality glass
    2) the focus ring has a broad range
    CPU: Intel CORE 2 Duo E6550 @ 3.6GHz w/ 1.29vcore (517*7)
    Motherboard:
    Gigabyte P35-DQ6
    Memory:
    Crucial 8500's
    Video:
    Nvidia 8800GTX
    PSU:
    Zippy 700W (fan modded of course)
    Xtreme n00berclocker
    Mar 2006
    San Jose, CA
    Your S3 IS has a 0-10CM super macro i think. Good for taking really good close up pictures.
    Jan 2006
    Quote Originally Posted by irev210 View Post
    Awesome example photo
    He took that with an EOS-20D, which means that it's bound to look good no matter what
    uncore challenged...
    Feb 2006
    ontari-ho (canada)
    Quote Originally Posted by Growly View Post
    when dealing with SLRs...the camera isn't what makes great photos, 9 times out of 10 its the glass
    i don't quote in my signature, but best WR ever...
    Quote Originally Posted by Jor3lBR View Post
    It holds the current WR for the least vcore required to run 4500Mhz stable (1.32vcore)
    i can't even make that shyt up ^^^
    Xtreme X.I.P.
    Dec 2005
    Quote Originally Posted by 3oh6 View Post
    couldnt agree more
    Here is how I rank it (depending on what you are shooting of course)
    1) Photographer
    2) Glass
    3) Image processing
    4) Flash
    5) Body
    All four parts support each other.
    The body is just a "facilitator", even a flash and accessories are more important than the body
    and honestly, my macro lens isnt even that sharp. Just an EF-S 60MM
    What I drool for is a 100MM macro.
    Motherboard:
    Gigabyte P35-DQ6
    Memory:
    Crucial 8500's
    Video:
    Nvidia 8800GTX
    PSU:
    Aug 2005
    3) Image processing
    Of course you mean on the PC after taking the shot, not internal camera processing because of course we all shoot in RAW here
    Very often the body can let down the shot, ie. using a 1.6 cropped sensor body with an EF 24-105 will lose a ton at the wide end vs a full frame body like a 5D.
    Another thing that a cropped sensor will rob you of is shallow depth of field with anything besides EF-S lenses (in the canon camp). That will reduce the impact of some shots and also give far worse looking portrait shots.
    Xtreme X.I.P.
    Dec 2005
    Quote Originally Posted by Nephilim View Post
    Heh, yes, I should have written post image processing.
    while I am no pro, a full framed SLR is a little out of reach for me.
    But still, if I had $2000 to upgrade to a 5D or buy $2000 in glass, I would buy more glass. What I could do with a few new lenses is far more advantageous to me over a better body, however everyone shoots different things so it is different for everyone.
    Motherboard:
    Gigabyte P35-DQ6
    Memory:
    Crucial 8500's
    Video:
    Nvidia 8800GTX
    PSU:
