Compressor - Aspera 2134E
Condenser - hand made
Freon - R22
Т idle -35С
T load (150W) -28С
Freon - R22
Т idle -35С
T load (150W) -28С
Much better, hop a fan on that condenser though if you havent and try to wrap the capillary line around the suction.
Originally Posted by Movieman
Fan on the condenser, cools it more but it'll also cool the compresser!!!
Where the suction line meat te evap coil it tightly for about 15mm up the line, this is for sub cooling (that right?)
Then wind the rest of the cap tube around the suction line, use tape to hold in place as needed.
Looking good ether way dude
Yeah! Get a Fan on the condenser, and you´ll probaly are getting better better temps!
But its looking good!
Phase Change Cooling
Better condenser coming your way posted it this morning Have fun![]()
Wow, that's a huge improvement bro, nice job. Good to see you're getting a better condensor too, definately put a fan on it.
Edit: I'm glad to see you're not using R12 on this one.
AHK! R-22 NO FAN!
Fans are criticle as heat builds the pressur rises inside the condenser and makes the compressor work harder and it will keep piling up till BOOM or the compressor fries!
Your lay out looks good, just ad the fan and perhaps a open ended shell for it to direct air flow you'll be set.
Bring back natural selection! No more warning lables!
The one and Only MG Pony
Today's Fortune Cookie:
- Imbesi's Law with Freeman's Extension: In order for something to become clean, something else must become dirty; but you can get everything dirty without getting anything clean.
- Life can be so tragic -- you're here today and here tomorrow.
- The chief danger in life is that you may take too many precautions.-- Alfred Adler
- Those who are too smart to engage in politics are punished by being governed by those who are dumb. - Plato
- Gunter's Airborne Discoveries: (1) When you are served a meal aboard an aircraft, the aircraft will encounter turbulence. (2) The strength of the turbulence is directly proportional to the temperature of your coffee.
- A wise man can see more from the bottom of a well than a fool can from a mountain top.
Now now, compressors just cough and and the electrical or thermal cutout kicks in. Just like CPUs don't explode if not cooled. Things just shut off.Fans are criticle as heat builds the pressur rises inside the condenser and makes the compressor work harder and it will keep piling up till BOOM or the compressor fries!
providing the thermal cut off hasn't fused, it can happen, rar but can.
um, do you have that suction line insulated? i cant really tell from the photo
if you wrap that cap tube around the suction line and insulate them both (i.e. so that no frost forms on the outside of the insulation), that'll assist in the subcooling even more. Make sure its closed cell foam at least
My Custom Pressure/Temperature Charts for Various Refrigerants
QX6700 @ 3900 | EVGA 680i |2 GB Corsair 8500 Dominator | 7800 GT SLi | Silverstone 1KW | Seagate 7200.9 Barracuda RAID 0 + Hitachi Deskstar 2TB RAID 0 | SS Phase w/ Cryostar Evap | MIPS Full Motherboard cooling
My Fake Quad Core is better than your real Quad Core! **cough**Barcelona**cough**
Lian Li Cube Case with Phase and Water DONE!!
Yes cutoffs and pressures switches,especially cutoffs which may have never kicked could not function just from corsion and never being triped,plus over heating can fuse the componates so they can,t trip.
thats why where dangerious pressures can be reached in cascades or even by you guys who mix gases.
The Laws of Thermodynamics say:
Zeroth Law: "You must play the game."
First Law: "You can't win."
Second Law: "You can't break even."
Third Law: "You can't quit the game."
Do you wanna Play Thermodynamics ????????I forgot "you must"
forgot to mention, at HVAC stores you can buy coil cleaner that will spray on and rinse with water, to rid and stop corrosion,of course damage already done can't be repaired. As long the corrosion is just the aluminum fins ,not a big problem, corrosion to the copper tube WILL compromise the pressure it will with hold.
The fan it is established on the given system, it simply it is not visible
Barnsley-Bill :thumbsup:
thats the biggest part of what we use the bio-dergradable stuff you simply wash down with water and if the coils are not real dirty the condensate on evaps in A/c will self flush and letting the water from condensors run on the ground or down a drain is OK.
Ya thats the big plus for us, as ground water purity is very high on every ones list here so more environmentally friendly the cleaner the better!
