Installed the new MB and packed the socket with grease this time!
Also pick up a Maze block to get rid of the NB fan and also added a VGA block for the 6600 cause the fan was loud as hell. And the circle begins... my temps are now 12c higher so I just bought a thermochill PA120.3 to run with my Swiftech 220 and am wondering if I need to run them on separate loops or use my existing pump to run them both. Currently I use the 665. The price just keeps adding up. I guess I'll have plenty of rad cooling but where to mount it all, I don't know, best to probably sell the 220 and get a thin 120 for the VGA and NB and run them separately. More cash!
Southbridge heat... I thought I could just cut off the heat pipe and leave the SB heatsink on, but temps were 60 to 70c, with a fan on it! So I took off the NB heatsink fan off an A8n-sli board and it fit barely. I've ordered the EVGA SB fan (I hate fans damnit) but what else am I gonna do. Seems like I'm chasing my tail here... buy two blocks to get rid of the fans, and because of that I'm gonna have to add a fan.
I'm running right now at 3.6 at 1.5 volts without issue. CPU temp is 0 at idle but quickly goes beyond 50 on load. I've also measured the load for the PSU which is a Antec True Power 550. It is 270 idle and 375 under load.
