Results 1 to 23 of 23
Thread: Components for Water Cooling?
    May 2003
    UK
    [newbie]
    I am looking to get some sort of water cooling setup for my new P4 3Ghz, I've been looking around, reading up, the usual before doing something like this. There is a few things I'd just like someone in the know to clarify for me, that is...what components do you need to build a water cooling system? So far I know of the following:
    CPU Waterblock - Sits on CPU
    GPU Waterblock (Not required, but a preference) - Sits on GPU
    Pump - Pumps water round the system
    Reservoir - Other than holds water, I'm not quite sure, could someone explain?
    Radiator - Cools the hot water before re-circulating
    Tubing - Carries the water round the system
    If I have missed anything, or have got it wrong about a components function, could anyone possibly fill in the gaps/errors for me?
    Many thanks.
    [/newbie]
    Nov 2001
    Wichita, KS
    Looks like youve pretty much got it covered. The res is highly debateable by some. Some prefer it, others hate it. Its a matter of opinion really.
    Looks like youve got it all listed there fine though.
    BTW, Welcome to the Xtreme!
    Nov 2002
    Boston/NJ
    Yeah, if you have a simple setup, a res is probably not needed. But, having a res does make filling the sytem a lot easier, since you can just fill the res to fill the system up with water. Without one, filling the sytem can be tricky, but still not that hard...
    Abit Is7-E
    P4 2.0A @ 3.2 160FSB with 1.63V
    2x256MB HyperX 3000
    Sapphire 9800 Pro
    Maze 3 / Maze4 GPU/ 6x11 Heatercore/ Hydor L30
    Apr 2003
    Sweden
    A fan or two for the rad (doh!) and maybe a shroud if its a heatercore. Then there are also the small stuff ofcourse like hoseclamps, batterywater and waterwetter or similar.
    May 2003
    Where do you get a shroud?
    To be or not to be...that is the question.
    Xtremely slow runner
    Nov 2002
    IMHO the res is only useful when you want to build a chiller, otherwise a T line is way better
    The page you are looking for is currently unavailable. The Web site might be experiencing technical difficulties, or you may need to adjust your browser settings.
    Av by Frisch This is not a Lime tree
    Jan 2003
    mayb a really dumb question, but what is a t-line and y is it better than a recevoir?
    Apr 2003
    A T is just a joint that is like a 3-way intersection: it's a straight line of pipe with another pipe coming off at a 90 degree angle. Sometimes people prefer these over resevoirs because they save space and still allow for bleeding.
    ~DP
    Nov 2002
    ~DP
    And it's way cheaper, and sometimes you have some flow problem with bad designed res and powerful pump
    Sep 2002
    Nottingham, England
    I use a res, just for simplicity of toping system up and bleeding it.
    Looks like everything else you have covered, don't forget some UV dye tho!!
    "There is only one thing better than having a linebacker in your office, and thats having two linebackers in your office"
    12.7Ghz folding for XtremeSystems
    Mar 2003
    Philippines
    what water do u use? distilled water? + what? i dont have water wetter here can i use coolant what ratio?
    Jan 2003
    canada
    this should help you http://www.overclockers.com/articles609/
    http://www.overclockers.com/articles599/
    AMD AthlonXP 2400+@14X166
    Asus A7V333
    ATI Radeon9700pro
    Performance Cooled by D-Tek & Danger Den
    Sep 2002
    Nottingham, England
    I use deionised water, approx 700ml, added 5ml of blue uv dye and 5ml of purple ice.
    Member
    Dec 2002
    Leics UK
    I allways use a res and a submerged pump, it just makes like so much easyer. But it does takke up more room.
    Nov 2002
    I use distilled water. BTW Water wetter is not a coolant but helps to kills the fungus and else and prevent any deposit
    Sep 2002
    Nottingham, England
    Plus if u have aluminium and copper mixed in a kit you'd better add Purple ice/Water Wetter otherwise you#ll get some reactions occuring and wrecking ur system quiet a lot!
    Turbo
    Guest
    Make sure you use distilled water and stay away from tap.
  18. #18
    i've seen people even use Evian or polish spring, but distilled water is cheaper
  19. #19
    Nov 2002
    ROFL Evian will harm your sys but it's good for your body
  20. #20
    Apr 2003
    Sweden
    If you use WaterWaetter be sure not to use to much.
    here is a small comparison of temps using WW;
    http://www.bunkermentality.net/wetter.html
    btw:
    My DD res cylinder cracked a while back after a few days, could this be because of WW? I read that someone else had his Poseidon res cracked and according to Poseidon this was do to the fact he had used WW. Anyone else had this problem?
  21. #21
    Jan 2003
    canada
    the DD res is real crap it's not WW
    you're not the first how had this problem
    Asus A7V333
    ATI Radeon9700pro
  22. #22
    Apr 2003
    Sweden
    I think it strange that WW would cause this, but for the res to spontaneously just start to crack in 5'000 places is even more odd. There were no +-pressure in my res so that was not the problem.
  23. #23
    Nov 2002
    That's really weird, i don't think it's a material problem because it would crack in one place. Anyway the dd res is crappy
