is primoflex tubing anygood?http://www.moddersmart.com/index.php...product_id=108
Get tygon if you want the absolute best tubing. I hear primoflex clouds easily.
Tygonthane PURnow I'm waiting for the insults...
Lenovo Thinkpad X220 - Core i5 2410m, 4gb
waiting on 28nm video cards...
how can you tell primoflex gets cloudy if the tubing is colored?
750W Thermaltake Modular PSU
DFI UT X58-T3eH8
Core i7 920 @ 20 X 200 1.325V
CORSAIR XMS3 DHX 4GB (2 x 2GB) DDR3 1600
768 MB EVGA 8800GTX
1 X 36GB WD Raptor
2 X 150GB WD RAPTORS
1 X SpinPoint P Series SP2504C 250GB
1 X Maxtor 6L300S0 300GB
16 X NEC DVD Burner
7 120mm Yate Loon LED Intake Fan
4 120MM Yate Loon Exhaust Fan
28" HANNSPREE Monitor
Watercooling Loop:
1 X PA120.3
1 X PA120.2
2 X Laing DDC's w/EK-DDC Dual Turbo Top
7 X Yate Loon Blue LED Intake Fans
4 X Yate Loon Blue LED Exhaust Fans
1 X Swiftech GTZ
1 X GPU EK Fullcover Waterblock
1 X XSPC Dual Bay Reservoir 5.25" with Bubble Window
I actually really like my blue primoflex...like the name says it is more flexible than most...
DFI UT X58-T3eH8
768 MB EVGA 8800GTX
1 X 36GB WD Raptor
16 X NEC DVD Burner
Watercooling Loop:
1 X PA120.3
1 X PA120.2
1 X Swiftech GTZ
I got the blue UV tubing, not bad... It's very 'squishy' by comparison. (I ordered up a few different types of tubing, kinda mixed it up and used a variety when doing my tubing setup). Two things I don't like about the blue UV stuff.
It's not really really glow bright under UV, and it attracts dust. the tubing is almost "sticky". It can run easily though, very wiggly tubing, but I like it in the end.
