+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 25 of 32
Thread: SS Phase advice
    Xtreme Cruncher PanteraGSTK's Avatar
    Dec 2006
    Texas
    0
    SS Phase advice
    I'm thinking of moving over to phase, but there are a few questions I have not been able to find answers to. I understand insulation and the risks involved, but what I want to know is why so many phase users seem to kill motherboards and cpu's so often? I can't afford to kill my parts. I like having spares. I know that sounds dumb since I'm willing to spend the money for a phase unit. The only reason I'm even considering it is because I have found a number of units for around $300 instead of ~$900 when new. If the units I want sell, or I don't think my components will survive, I'll wait and get a custom unit built. So, considering my meager budget, would you spend the money on a cheap, used phase unit (that I can use for years, hopefully) or get a new cpu or better memory?
    I hate asking questions like this, so bear with me.
    -150c Club Member n00b 0f l337's Avatar
    May 2005
    NJ
    11
    I'd save up to $450-500 and get a brand new unit from a builder who's willing to build more towards your budget.
    As for why things die, with the very cold temperatures many are too enthusiastic with there vcore. Thus there CPU might die. Condensation kills most though, and thats simply not proper insulation being done. Or trusting insulation solutions like Vapochill's with the lga system (that metal really does move the heat around).
    Quote Originally Posted by Movieman
    Thanks for the compliment but unlike that bartender you mentioned I'm not sleeping with you no matter what you say!
    Mar 2007
    North Wales (UK)
    0
    Hi n00b 0f l337 I seen this post and it got me thinking about this too.
    I've got Gray on my side though so I think I should be safe as he is building me a unit at the moment
    Kind Regards
    x2o
    Xtreme Addict Exahertz's Avatar
    Dec 2006
    Maryland
    0
    would you guys say that its justifiable to spend ~$1500 on tools and parts and build a unit (which could be sold to make back some of that) or just buy a manufactured unit for $900.
    i like having the tools for anything i have experience with. who knows... maybe my heatpump in my house might break and i could fix it.
    Current System Build
    Designaton:" Rad Hat "
    __________________
    • Mother Board, RAM and CPU:
      Mobo: Asus Maximus Formula (SE) BIOS 1207 | CPU: Intel q9650 @ 3.80GHz Vcore 1.272v | RAM: Crucial Ballistix Tracer PC2 8500 4x1GB
    • Graphics Processor:
      GPU: BFG 8800GTX | BFG 8600GT (Quad Monitor Setup)
    • Hard Drives:
      RAID: 2x 74GB Raptors on RAID 0 for OS Drives
    • Case and Power Supply:
      Case: Antec Case | PS: OCZ ProXstreame 1000W
    • Water Cooling:
      Pump: Swiftech MCP655-B | Rad: Dual Swiftech MCR320's | Fans: 6x Yate Loon D12SH-12's (W/ Variable RPM Rheostat) @ 88CFM Max Each - 528CFM Total!!!
    • (Water Blocks and Fittings):
      CPU: D-Tek Fusion Block | GPU: Danger Den Full Coverage 8800 Block | Mobo: EK's Mosfet, NorthBridge and SouthBridge Blocks
      Res: Swiftech Micro | Tee's: 4x MartinM's High Flow Copper Tee's | Elbow's: None | Y's: None
    Flow Order: >> Rad's 1 & 2 in parallel > Res > Pump > CPU > GPU > SB > NB > Mosfet 1 > Mosfet 2 >>
    Temperatures: CPU: 57°C Max, Running Prime95 | GPU: 58.3°C Max, Running 3Dmark | NorthBridge: Untested!
    Last Updated 11/11/09
    Dec 2006
    Texas
    0
    Quote Originally Posted by n00b 0f l337 View Post
    Thats what I was thinking, but you know how it is when you see what seems to be a good price. I think I'm going to get one of jinu's or chilly's units if either one of them can get better. Maybe building phase units is more hazerdous than we think? Hope those guys get better. Not being selfish, I just want a quality unit. I plan to migrate to quad core and will need a unit that will handle the heat. I just need to wait.
    Thanks for the responses.
    May 2005
    NJ
    11
    Markets cornered as it is, anyones chance of building and selling phase units is very limited. I build and sell and will probably never break even!
    As for buying a manufactured unit for $900, we all recommened against them anyway. Brand new, much better performing unit, from any custom builder will run around $650-700 when cased.
    But most of us also offer more budget affairs, or might have some inventory to move.
    Mar 2007
    North Wales (UK)
    0
    Quote Originally Posted by Exahertz View Post
    I would think that depends on how enthusiastic you are about wanting to build a phase unit I'm new to all this so some of the builds I've seen seem really mad especially the stage 3 and upwards but very cool though.
    Kind Regards
    x2o
    Dec 2006
    Maryland
    0
    what exactly do you mean by cornered?
    __________________
    • Hard Drives:
    • Water Cooling:
    May 2005
    NJ
    11
    As in, there are tons of builders, competition for prices has sorta put the price of the average unit as low as it can go with Sellers keeping up warranty and such. There is not a large demand and a small supply, theres a medium sized demand and a supply that is currently large enough to overly provide the demand.
    Dec 2006
    Texas
    0
    Plus, they would be able to customize it to your specs and still be cheaper than a "retail" unit. Thats why I'm getting one built when I decide what it will be used on. That, and I'd have to choose a builder. That is enough to make you go crazy. Too many good people to choose from. But that isn't a bad thing at all...
    Oct 2004
    0
    woa $1500... i got my tools and material for $500
    Dec 2006
    Maryland
    0
    Quote Originally Posted by potkit View Post
    my tools
    Inficon Vortex recovery unit*
    Inficon Wey-Tek charging scale
    Extech 2 chanel thermometer
    Omega 6 chanel thermocoupler scanner with alarm outputs
    Welch 8925 vacuum pump*
    Welch 1402 vacuum pump
    Welch 8803 vacuum pump
    Turbo-molecular UHV pump
    Granvile-Phillips Convectron vacuum gauge (atmosphear to 1x10^-4 Torr)
    Ion vacuum gauge (1x10^-4 to 1x10^-16 torr)
    Braz-o-matic MAPP torch
    *Cheapo* Oxy-Acetyl torch (full human error warranty)
    Argon, Oxygen and Acetylene bottels w/ regulators
    30 lbs DuPont R22
    2 lbs. safety silv 15% and Flux
    Imperial flaring and Swagging die set .125", .25", .375", .5", .625", .75" .875", 1", 1.25", 1.5", 1.75"
    2 Yellow jacket Gauge/charging manifolds
    60 tubes of dielectric grease
    3 EPA certifications
    1200 page book (modern refrigeration and air conditioning)
    and one good machinist (Duniek)
    Plus much more usefull, but not so phase related tools.
    Thats way more than $1500.00
    __________________
    • Hard Drives:
    • Water Cooling:
    Dec 2006
    Texas
    0
    Ok, I can get a mach II for $300 shipped ( i think shipped). That is a great price, but I would be jumping into phase without researching for a year. Literally, to me this is a HUGE decision, especially since I just perfected my infinity. I know nothing of phase and stumbled on this deal. If I can use this with a quad core (with or without modding in) that would be the deal breaker. I've read that quads and phase don't mix due to the heat output of the quads. As far as my current setup, I think I'd have to buy a new board to even get more out of my cpu, that or mod the crap out of my S3 voltage wise.
    Help. I'm too chicken to make a decision like this without knowing anything about phase.
    Dec 2006
    Maryland
    0
    __________________
    • Hard Drives:
    • Water Cooling:
    Admin runmc's Avatar
    Mar 2003
    North Texas
    10
    It won't work on a quad core - IMHO
    Make sure the mounting enclosure is designed to fit your motherboard. It may be for AMD or Intel. It may be for a different socket mobo than you have.
    Save your money and buy a car
    Jesus is the remedy
    -100c Club Member Blaster's Avatar
    Apr 2004
    Portugal
    0
    quads do work on phase, if its properly designed
    Dec 2006
    Texas
    0
    Quote Originally Posted by runmc View Post
    I couldn't even get tires for $300 I'm not going to get it. I'd rather have a custom unit built. That, and I want to do as much research as I can before buying. Condensation turned me away from water cooling, but phase is worth it to me to learn about it. Thanks for the replies.
  18. #18
    Xtreme Member MrDeeds's Avatar
    Jun 2006
    Chicago, IL
    0
    This is no sort of knock against you and i hope you dont take it that way but what sort of guarantee do you have that someone would want to buy a phase unit from you.
    Like nol said, theres a lot of competion already and if someone had to choose who to purchase from for the same price. More than likely its going to be an established builder.
    I say if this is going to be your hobby then it isnt alot of money to spend to build your own system and a couple cheap builds to sell. I just wouldnt go into it thinking its an easily profitable venture.
    Asus Commando 6600 week 28B @4.2 1.475v(1.475 in bios) 525x8 4-4-3-4 1150mhz 2.3v
    2x1gb Patriot Pc-8000 Xbl | X1600 Pro | 2 Wd 36gb Raptors
    Seagate 750gb | Vapoli V2000B SS | Pc p&c Black Silencer 750
    Quote Originally Posted by chron
    Its DDR2 - doesn't it need to be ran with 2 sticks at a time?
  19. #19
    Dec 2006
    Maryland
    0
    no offense taken Deeds. i understand that i wouldnt be able to sell them as a business but maybe i could get some bites on ebay. surely i wouldnt even get half of what the parts are worth, but as i build bigger and better units id have to sell off my surplus to make room.
    __________________
    • Hard Drives:
    • Water Cooling:
  20. #20
    Mar 2003
    North Texas
    10
    Quote Originally Posted by Blaster View Post
    He said a Mach II.. I don't think a Mach II can handle a quad.
    Jesus is the remedy
  21. #21
    Dec 2006
    Texas
    0
    And that's all I needed to know. No mach II for me. Oh well. Now I can save for a big build. Thanks for your advice guys.
  22. #22
    Xtreme Member Hot'n'Chilly's Avatar
    Mar 2007
    0
    Very nice thread, I am thinking about going VAPOCHILL myself for my next rig and am begining to gather info too.
  23. #23
    Aug 2006
    0
    Quote Originally Posted by Hot'n'Chilly View Post
    No Vapo for a Quad-o unless you mod-o. Ohhh.
  24. #24
    Xtreme Member Barnsley-Bill's Avatar
    Dec 2006
    Good old Yorkshire
    0
    I was thinking the same when i wanted to use a ss phase unit but looking at guys who build them on the forum the performance of theres are by far better than the vapochill units and cheaper in many respects.
    this is the road i went down and im a happy bunny now .
  25. #25
    Mar 2007
    0
    How long until the manufacturers start making Quad ready setups? Any guesses?
+ Reply to Thread
