I was thinking about how to set up my loop with both permanent inline filter
and reservoir at the same time and come to idea which i would like to discuss.
The example of big inline filter from Pentek:
http://www.pentekfiltration.com/pdfs...20Standard.pdf
10Clear version is what i am about.
There is also a good 1micron filter cartridge with very low pressure drop, suitable
for the permanent filtering:
http://www.pentekfiltration.com/pdfs/310111%20ECP.pdf
ECP1-10 filter will have very low pressure drop for typical flow rates.
This filter, fully filled with water, will contain several liters.
The only thing left is the hole for water filling/ air bleeding.
It can easily be created in the bottom of the filter housing, in the center.
Turned upside down, the filter then can be used as a one huge super reservoir/filter combo. Definitely not for internal use, this will be one hell of external reservoir with huge capacity and filtering at the same time.
For those who like all super-huge, there is even bigger housing versions and bigger filters with even lower pressure drop.
