Page 1 of 2 12 LastLast
Results 1 to 25 of 29
Thread: Cool Labratoy Liquid Pro from SVC.com
    D.F.I Pimp Daddy
    Jan 2007
    Still Lost At The Dead Show Parking Lot
    Hey has any one else purchased their Liquid Pro from SVC and not seen any kind of temp drop compared to AS5? Just wondering because I have changed the tim and reseated this cooler 2 times now and have yet to see any temp difference between this and AS5!
    Mine did not come in a Factory package from Coollabrotories it was sent in a small bag I'm starting to wonder if its fake and not the real deal.
    SuperMicro X8SAX
    Xeon 5620
    12GB - Crucial ECC DDR3 1333
    Intel 520 180GB Cherryville
    Areca 1231ML ~ 2~ 250GB Seagate ES.2 ~ Raid 0 ~ 4~ Hitachi 5K3000 2TB ~ Raid 6 ~
    Xtreme Cruncher
    Oct 2006
    Boston, Massachusetts
    Quote Originally Posted by Brother Esau View Post
    all of it comes in little bags. its the only way ive gotten mine. It comes in a BD syringe and is about 5ccs worth. Squirt a bit out onto something and if it balls up its either mercury, or its liquid pro =D Liquid pro is more dependent on the contact of your HSF to the IHS than most other things that are silicone based with silver like AS5. If your HSF and IHS dont make good contact, theres less room for error in that dept from my experience with CoolLab
    D.F.I Pimp Daddy
    Jan 2007
    No I lapped the heatsink and its dead flat and I also checked the chip from corner to corner for true as well and that shows flat as well.
    SuperMicro X8SAX
    Xeon 5620
    Oct 2005
    wasn't there some problem with it eating through sinks? what's your experience?
    dothan 730 @ 2.6Ghz l p4c800ed l 4x512MB bh5 2-2-2-5 5:4 ~3v l Antec Neo 480
    e6600 @ 3.6GHz l P5W64 WS Pro l 4x1GB D9GMH (B6-3) 3-3-3-3-12 4:3 2.2v l PCP&C 750
    May 2006
    Canada
    I have some coollaboratory liquid pro. I didn't get it in a bag.
    I bought it off ebay and it just came in a syringe taped onto some pamphlet.
    I have found a few times that if i didn't put enough of the Liquid Pro my temps would b worse than b4.
    Maybe just double check that you used enough.
    To answer mcoleg's question:
    It specifically says in the instructions to NOT use it on aluminum heat sinks because it will eat thru it. As for copper heat sinks it works great.
    On my old opteron 165 system the switch dropped my temps 3C from AS5.
    CPU: Q6600 @ 3.6ghz G0 Week 37B
    Mobo: Asus P5k Deluxe
    Cooler: TRUE 120 (150cfm Delta)
    2xHR-05
    2xHR-09
    Mem: G.Skill 4x1Gb 6400HZ
    Vid: HIS 4850
    HDD: 80Gb 16mb Cache Raptor
    500Gb 7200.11 Seagate
    PSU: Enermax Noisetaker 600w
    Case: Thermaltake Armor (4x120mm 104CFM Panaflo)
    3dmark06: 16k
    D.F.I Pimp Daddy
    Jan 2007
    well something isn't right because I have yet to see the difference using this stuff over artic silver 5 other than the fact that its a pain in the balls to spread.
    I would think that a thin coat applied to the IHS as well as the heatsink should be plenty.
    So how bout you guys chime in and tell me if you saw a temp drop from AS5 please.
    SuperMicro X8SAX
    Xeon 5620
    May 2006
    Philippines ^_^
    hey guys my hs is nickel plated but its really copper inside.. is it ok to spread the cool labs liquid pro??
    Asus P5W64 WS Professional , DFI Infinity 965P-S (testing)
    X6800 , E6750 es
    Micron Fatbodies , Micron D9gkx oem, Crucial 8000, Crucial Tracer 8500 (incomming)
    Ati FireGL V5100, Elsa FireGL V3100
    water cooling setup (EK 775 cpu block, swiftech NB Block, Swiftech pump, BI dual pass dual 120mm)
    Silverstone OP650
    raptors, baracuda
    D.F.I Pimp Daddy
    Jan 2007
    Yes! You will find that its not easy to spead on material other than copper but a small piece of coffee filter works well spreading it.
    SuperMicro X8SAX
    Xeon 5620
    Xtreme Cruncher
    Oct 2006
    The only thing you cannot use CoolLabs with is Aluminum based heatsinks or anything with aluminum in it, its corrosive since it contains Gallium and they react with eachother. I saw a 5C at least drop with CoolLabs over AS5, just get a microfiber cloth and apply it very very thin, I dont know what you could be doing wrong other than that.
    D.F.I Pimp Daddy
    Jan 2007
    I know thats what I am saying bro, I just don't get it? I should see some kind of gain over the AS5 but I dont! I spread it nice and thin and evenly with a piece of coffee filter which works like a champ and I have yet to see anything temp wise for improvement.
    SuperMicro X8SAX
    Xeon 5620
    Oct 2005
    no aluminum, gotcha. thanks guys, that makes sense.
    May 2006
    Philippines ^_^
    Quote Originally Posted by ChaosMinionX View Post
    tnxs mate..
    X6800 , E6750 es
    Silverstone OP650
    raptors, baracuda
    Feb 2007
    If you happen to have a silver waterblock, don't use it either, it'll ruin it.
    Xtreme Cruncher
    Oct 2006
    Quote Originally Posted by theelectic View Post
    Gallium should not react with silver, what do you mean by "ruin"
    Champion
    Jun 2003
    cape town
    check these stains from a couple of months under coollaboratory liquid.
    does anyone know if this will void my warranty?
    and yes this is as clean as it gets withough lapping
    Jan 2007
    Vienna, Austria
    thats the way i got mine, when i bought it here in europe ...
    Click image for larger version.
    btw. there is also a thread over in the liquid cooling forum where this stuff gets discussed. see my post #40 there. guess i'm the only one who doesn't have that success with it ...
    http://www.xtremesystems.org/forums/...=135359&page=2
    Processor: Intel Core i7 990X
    Motherboard: ASUS Rampage III Extreme
    Memory: Corsair CMT6GX3M3A2000C8
    Video Card: MSI N680GTX Lightning
    Power Supply: Seasonic S12 650W
    Case: Chieftec BH-01B-B-B
    May 2006
    Canada
    I highly doubt your cpu is flat without any kind of lapping. Pretty much every C2D i've seen has been concave in the middle.
    Its an easy test. Put a bit more liquid pro in the middle. If it gives you better temps then your cpu is probably concave.
    If that's the case then lap the cpu too.
    2xHR-05
    2xHR-09
    Vid: HIS 4850
    3dmark06: 16k
  18. #18
    Aug 2006
    My Conroe is lapped, and im using an Apogee water block, so I have pretty good contact. My temps with AS5 are 40-41c idle, 51-52c load. Using Coollabs Liquid Pro my Temps are 36-37 idle and 47-48c load. I honestly don't think the Liquid pro needs to be removed from the IHS, because I had remounted my water block with the Liquidpro still on there, I just put some more and I got the same temps.
    "Do not ask to find fault, ask to learn. For if the ignorant man asks to learn, then he is more knowledgeable than a knowledgeable man, who asks to find fault." - Commander of the Faithful Imam Ali A.S.
  19. #19
    Xtreme Cruncher
    Oct 2006
    Quote Originally Posted by flytek View Post
    It looks like youve already lapped it a bit on the outside of it. If so I dont think you have to worry about warranties, also you OC that chip no? again you wouldnt have to worry about warranties. That stain is the gallium in the little pores on the surface of the metal, easily removed using arctic clean kit and a plastic based steel wool like whats used in painting to give a rough look.
  20. #20
    Feb 2007
    Whatever else is in there doesn't like silver. I can't find the thread right now but someone used the stuff with a silver G5 Storm and it messed up the block big time.
  21. #21
    Oct 2004
    London UK
    Quote Originally Posted by ineedaname View Post
    I thought they were designed to be concave and expand to flat when heated but i also read Marvel comics lol. The difference between the ceramique and coollaboratory was marginal at best I bought some and it just seems to be a refreshing alternative rather than a technological breakthrough. Is lapping your CPU a good Idea? maybe I should poll on this
    I'm heavy handed and it could all end in tears!
    Respec'
    System:Bunch of crappy overclocked PC's that cost an arm and a leg
  22. #22
    Jun 2005
    None of my TIM ever comes with retail packaging. I mainly use AS5.
  23. #23
    D.F.I Pimp Daddy
    Jan 2007
    Generally I would not think twice about it but the add in NewEgg as well as Cool labratory show it in a package and the whole temp thing made me curious as to why.
    SuperMicro X8SAX
    Xeon 5620
  24. #24
    Xtreme Cruncher
    Oct 2006
    No other compound except mercury would act like Liquid Pro, like I said you either got Liquid Pro or mercury haha, its not fake you cant fake liquid metals at room temp.
  25. #25
    Xtreme X.I.P.
    Apr 2005
    Also the best and cheapest way to clean this stuff off is ... tooth paste
    using this stuff for 1.5 years - gave me 5C drop compared to ceramique paste. Good contact and flat surfaces of CPU/sink matters alot here (as well as with regular ceramique pastes). Also note this thing is conductive - don`t spill any on your hardware when powered on
