Hi.
I've been lurking around for some time and learned alot about water cooling.
Great source of information.
I am building new watercooling setup for dual socket machine, specs are:
--2x Xeon s771 Clovertown (Quad) E5320@1860MHz. Currently only mildly overclocked to 2.7GHz. But i hope, with the recent progress with SPD programming, decent overclocking will be possible, to 3.3-3.5GHz.
--MB Tyan Tempest 5000XT
--8x1GB FB-DIMM 667
--Stacker STC-T01
--PSU - single Zalman ZM600-HP. I am planning to install second one, dedicated for CPUs.
--Video is not important for now (7300GT), but later i will get top model from either NVidia or AMD/ATI, depending on which one will be better. Probably 2, for SLI/CF
Here are the main WC components I am planning to get:
--Radiator: 2x PA120.3 (already ordered). Will run in parallel, mounted over the case top with custom-made mounting solution.
--CPU Waterblock: 2x D-Tek FuZion
--Chipset Waterblock - Silverprop Cyclone NexusSX. I want NB water cooling
for higher FSB overclock. Also, 5000X chipset has quite a high thermal output,
32W TDP nominal, 50W estimated at 500MHz, actual load may be higher (as usual, Intel TDP is not the maximal thermal load )
--Pump: 2x Alphacool Laing DDC-Pump 12V Ultra with Alphacool top. Both will be mounted in the 4-in-3 module in Stacker. Question: will they both fit?
They will be ran in the same loop mainly for redundancy, but also for increased performance. For the later, pumps will be separated by some water resistant WC components, namely CPU and/or chipset blocks in the loop.
--Tubing: 1/2" ID (3/4" OD) Tygon Silver Antimicrobial Tubing from Petra.
Want give it a try, i like the idea and look of it.
--No reservoir, just T-line with DD fillport.
--I also want to include Pentek filter in the line, in parallel with Shutoff Ball Valve. For the first several days the valve will be closed so all water flow will go through filter. Then i will open the valve to reduce resistance. Part of the flow will still be going through filter, providing permanent filtering at very little overhead.
That is all, concerning WC setup for now. Later i may be adding custom-made waterblock for memory, as FB-DIMMs runs extremely hot. And, of course, future video cards will be watercooled as well.
