Setup:
Lian Li Mid-tower Case
Gigabyte 965P-DS3
E6600 + Tuniq Tower 120
4 gb G.SKILL DDR800
OCZ 600 watt GameXtream
eVGA 8800 GTS
Sound Blaster X-Fi XtremeGamer
Yesterday, after installing my new Tuniq T120, I began overclocking my E6600. I found that at 3.4 ghz (multi = 9, FSB = 378) with 1.531~ volts in bios (around ~1.49 after vdroop) was seemingly stable. I ran orthos small FFT for 2 hours with no problem, then ran blend for 6 hours with no errors.
So last night, as usual when I headed to bed I turned off my PC and fell asleep. This morning I wake up, push the power button on the tower, and find something rather disturbing. The power LED goes on, fans start to spin, and then after about ~2 seconds it shuts off. A few seconds later that repeats, and on and on and on... I never get any video on my monitor and it just loops forever.
At this point I remove the CMOS battery (well... to clear the CMOS) and boot it up with default bios settings. It works now, so I figure it was just some weird fluke. I set the PC to 378 X 9 once more, and up the voltage to 1.55 in bios (thinking I might have just had slightly too little voltage for it to boot cold). Once again... same thing happens and I have to clear the CMOS once more. I'm running it at 8 X 400 right now (3.2 ghz CPU, 1:1 800 mhz for memory) and it's fine as far as I can tell.
So I guess my question is, how come it was Orthos stable yesterday at 3.4 ghz, yet this morning when I try to boot up it won't even post?
Thanks very much in advance.
