Ok I just got finished tracking down all the relevant info and it looks like we have the ability to earn double the points on these projects. When sieving ranges for PSP, the fact.txt files that contain the factors can ALSO be submitted to SOB Sieve to help them out also. You must be running the proper DAT file which is included in the guide that I sent out and is the same file included in all the guides floating around the net. Now here is the process you need to follow to get most out of your time.
1) Submit your results to SOB Sieve, make sure you create an account and log in first!
http://www.seventeenorbust.com/sieve/
2) Submit your results to PSP Sieve
http://www.psp-project.de/sieveimport.php
3) Reserve another range and repeat!
http://www.mersenneforum.org/showthread.php?t=2666
I hope this is correct, I'll know within a day or so
