Can someone help me with a download manager?
My internet here at school is terrible so about every hour i become disconnted, meaning every time i try and download anything that takes longer then an hour (which everything does, because i only get 15kb/s) it will time out and i have to start over.
Is there some sort of low wieght download manager that will let me resume downloads? I hate all my progress just gets deleted every time my internet goes on the fritz.
60 days free trial http://www.internetdownloadmanager.com/ one of the bests out there
cool thanks its working great and was easy to set up.
might have to buy it..
theres also freedownloadmanager.org. I use it quite a bit. Its not as light as IDM, but its free, and virus/spyware free
Fold for XS!
You know you want to
I have tried many. And finally I rested on the one with the least amount of bugs:
http://westbyte.com/ida/
I was using Download Studio, and it was great. If they could only fix some of those annoying bugs I would buy it. IDA works with Flashget too (for firefox).
My watercooling experience
Water
Scythe Gentle Typhoons 120mm 1850RPM
Thermochill PA120.3 Radiator
Enzotech Sapphire Rev.A CPU Block
Laing DDC 3.2
XSPC Dual Pump Reservoir
Primochill Pro LRT Red 1/2"
Bitspower fittings + water temp sensor
Rig
E8400 | 4GB HyperX PC8500 | Corsair HX620W | ATI HD4870 512MB
I see what I see, and you see what you see. I can't make you see what I see, but I can tell you what I see is not what you see. Truth is, we see what we want to see, and what we want to see is what those around us see. And what we don't see is... well, conspiracies.
- You may not post replies
- You may not edit your posts
Forum Rules
