Results 1 to 9 of 9
Thread: 10K HD Cooling Question(s)...
    Sep 2006
    Question 10K HD Cooling Question(s)...
    Hello, I am about to purchase a 10K WD Raptor.. and I was wondering how dangerous this was, regarding high temperatures... would placing it directly in front of the two intake fans of my Case and mounting one of those Aluminum HDD Dual Fan Cooling Device be sufficient? How hot do these things run and are supposed to be kept at? Thank you very much! =)
    - BMN
    I am Xtreme
    Aug 2003
    Dont get a cooler. Not needed. I run both my raptors in an antec 3.5>5.25 converter bay with a 7200 drive in there as well with no fan on my desk. No overheating or issues. A single intake fan is more than enough.
    Phenom II 940 BE / ASUS M4A79 / HD5770 Crossfire
    3770mhz CPU 2600mhz NB | DDR1040 5-5-5-15 | 900/1250
    Xtreme Mentor
    May 2005
    Westlake Village, West Hills
    Raptors run hot, I wouldn't run 4 stacked Raptors without some kind of active cooling. A low speed fan 80mm + is good enough. If you are just getting a single Raptor, you can pretty much get away with passive, or just like fireinside said.
    PC Lab Qmicra V2 Case SFFi7 950 4.4GHz 200 x 22 1.36 volts
    Cooled by Swiftech GTZ - CPX-Pro - MCR420+MCR320+MCR220 | Completely Silent loads at 62c
    GTX 470 EVGA SuperClocked Plain stock
    12 Gigs OCZ Reaper DDR3 1600MHz) 8-8-8-24
    ASUS Rampage Gene II |Four OCZ Vertex 2 in RAID-0(60Gig x 4) | WD 2000Gig Storage
    Theater ::: Panasonic G20 50" Plasma | Onkyo SC5508 Processor | Emotiva XPA-5 and XPA-2 | CSi A6 Center| 2 x Polk RTi A9 Front Towers| 2 x Klipsch RW-12d
    Lian-LI HTPC | Panasonic Blu Ray 655k| APC AV J10BLK Conditioner |
    Feb 2007
    I'd be more concerned with your overall case airflow. I run a 150GB Raptor with another 7200rpm Seagate on top of it, no fan blowing on them, with 20C ambient they never get above 30C. I just have one 80mm front intake and 120mm exhaust. The drives are above the 80mm intake. As long as I keep the 120mm exhaust up full (Antec Tricool) temps are OK (read in Everest). If I turn the 120mm down all the way, then temps go up to around 37C.
    D.F.I Pimp Daddy
    Jan 2007
    Still Lost At The Dead Show Parking Lot
    Remarkably enough I just bought my first Raptor and it runs @ 28- 30c @70f ambient temp.
    SuperMicro X8SAX
    Xeon 5620
    12GB - Crucial ECC DDR3 1333
    Intel 520 180GB Cherryville
    Areca 1231ML ~ 2~ 250GB Seagate ES.2 ~ Raid 0 ~ 4~ Hitachi 5K3000 2TB ~ Raid 6 ~
    V3 Xeons coming soon!
    Nov 2005
    New Hampshire
    I have 2 in the front bottom of a Lian Li PC70 and they are fine with the 2-80's in the front blowing in.
    One night I did some work on the machine and forgot to plug in the front fans.
    An hour later I put my hand near the drives and could feel the heat coming from them 5" away..Got the fans back on and cool in minutes.
    I don't think they need lots of air but I do think that having some constant airflow will do the trick and definately increase the lifespan.
    The XS WCG team needs your support.
    A good project with good goals.
    Come join us,get that warm fuzzy feeling that you've done something good for mankind.
    Quote Originally Posted by Frisch View Post
    If you have lost faith in humanity, then hold a newborn in your hands.
    Jun 2006
    Chicago, IL
    I've had two 36gb raptors with 2 more hard drives on top of them with nothing but the 80mm intake fan on my case as the only cooling for over 3 years. No extra cooling is needed.
    Asus Commando 6600 week 28B @4.2 1.475v(1.475 in bios) 525x8 4-4-3-4 1150mhz 2.3v
    2x1gb Patriot Pc-8000 Xbl | X1600 Pro | 2 Wd 36gb Raptors
    Seagate 750gb | Vapoli V2000B SS | Pc p&c Black Silencer 750
    Quote Originally Posted by chron
    Its DDR2 - doesn't it need to be ran with 2 sticks at a time?
    May 2006
    Canada
    I have a 80gb raptor and i have just 1 fan blowing it cool. You make it sound like they're super hot but they're only a bit hotter than regular 7200rpm hdd's.
    CPU: Q6600 @ 3.6ghz G0 Week 37B
    Mobo: Asus P5k Deluxe
    Cooler: TRUE 120 (150cfm Delta)
    2xHR-05
    2xHR-09
    Mem: G.Skill 4x1Gb 6400HZ
    Vid: HIS 4850
    HDD: 80Gb 16mb Cache Raptor
    500Gb 7200.11 Seagate
    PSU: Enermax Noisetaker 600w
    Case: Thermaltake Armor (4x120mm 104CFM Panaflo)
    3dmark06: 16k
    Sep 2006
    Thanks guys, this really helps =)... I'm very paranoid with Heat on my whole system, but I don't like water cooling (I find them expensive, complicated, and I Hate the Radiators out there, etc)... The HD Rack is directly infront of the 2 Intake Fans, So I'll just stick it in there with an empty HD Slot on top and on the bottom of it...
    I'll log on to Tigerdirect and place an order for it right now... I'll post later how it worked out
    Thanks again!!! =)
    - BMN
